korrupt66 Posted March 23, 2009 Share Posted March 23, 2009 I cant seem to get the damn bottom slider pin out. I've tried hammers, heat, wrenches and all it will do is spin now. I was just going to get a new caliper support bracket but after my last post seems this is a common problem. So I'm hoping for a common solution. FYI 97 Leg 14 inch wheels. Link to comment Share on other sites More sharing options...
tcspeer Posted March 23, 2009 Share Posted March 23, 2009 Have you tried to lock vice grips on it, and then tap the vice grips with a hammer? Link to comment Share on other sites More sharing options...
korrupt66 Posted March 23, 2009 Author Share Posted March 23, 2009 Unfortunately I don't think any tapping is going to work. I put a wood block up against it and pounded away and nothing. Ive already burn the boot off so I'll end up getting new pin and boot. So I'm not looking to be nice I just need it out. Link to comment Share on other sites More sharing options...
Gloyale Posted March 23, 2009 Share Posted March 23, 2009 In a real pinch I've removed the caliper bracket and used a drill press to drill a hole through to the back side of the slider pin hole. then you can whack the slider pin out with a punch through said hole. If you do this, use lots of cutting oil on the drill bit. I did this as a TEMPORARY solution until a replacement bracket could be found. I am unsure of the longterm safety of a modified caliper backet. USE AT YOUR OWN RISK. Link to comment Share on other sites More sharing options...
hohieu Posted March 23, 2009 Share Posted March 23, 2009 There's a rubber bushing on the end of the lock pin that swells up and can be a bear to remove. Banging away usually won't help. You need to apply constant pressure and it will normally slide out very slowly. Link to comment Share on other sites More sharing options...
bheinen74 Posted March 23, 2009 Share Posted March 23, 2009 i would just get a new bracket, used even better. don't really think the slide pins are normally a replaceable alone, meaning you are not going to simply remove it anyhow. They aren't threaded in if that is what you think. Its a press fit not to be removed Link to comment Share on other sites More sharing options...
johnceggleston Posted March 23, 2009 Share Posted March 23, 2009 bheinen74 said: i would just get a new bracket, used even better.don't really think the slide pins are normally a replaceable alone, meaning you are not going to simply remove it anyhow. They aren't threaded in if that is what you think. Its a press fit not to be removed the slide pins in a 96 leg L are threaded, one threaded pin one bolt. the pin has flat spots on it for a wrench. i can't remember if it's front or rear, but the fronts would be different than outback. i'm surprised they don't thread in. Link to comment Share on other sites More sharing options...
Gloyale Posted March 23, 2009 Share Posted March 23, 2009 bheinen74 said: Its a press fit not to be removed No, it is supposed to slide right out. Link to comment Share on other sites More sharing options...
Gene J Posted March 23, 2009 Share Posted March 23, 2009 The pins can be purchased with the boots and o ring separately as a repair kit. I had to buy new brackets. About $75 each as I recall. A parts guy at a local Car Quest said packed calipers have the bracket included. This might be a good way to go. Link to comment Share on other sites More sharing options...
korrupt66 Posted March 23, 2009 Author Share Posted March 23, 2009 I got a junk yard caliper with bracket for $25. Rusty as all hell but the pins slide right out. Should be good to go. Thanks for all the help! Link to comment Share on other sites More sharing options...
Gloyale Posted March 24, 2009 Share Posted March 24, 2009 (edited) double post, see below Edited March 24, 2009 by Gloyale double post Link to comment Share on other sites More sharing options...
Gloyale Posted March 24, 2009 Share Posted March 24, 2009 Gene J said: A parts guy at a local Car Quest said packed calipers have the bracket included. This might be a good way to go. The guy could have been wrong. Or you guys could get a better supplier out there. All the *loaded* calipers I've seen for purchase DO NOT have the bracket, it is the Caliper only. (including from my local Car Quest) Just a FYI Anyhow, Glad to hear that it is fixed. Junkyard is a perfect solution in some cases. Link to comment Share on other sites More sharing options...
Bigbusa Posted March 24, 2009 Share Posted March 24, 2009 I got a new pin with the new caliper for my 96 obs. I couldn't get the old pin to come out so I just used it and tossed the new one. Link to comment Share on other sites More sharing options...
