Chip Posted March 25, 2009 Share Posted March 25, 2009 Has anyone tried the Whiteline swaybar links on a 2003 Impreza with rear drum brakes ? I'm talking about the p/ns KLC19 and KLC20's. PDM racing says they may not fit models with drum brakes and I was wondering if anyone had tried them. Link to comment Share on other sites More sharing options...
yohy Posted March 25, 2009 Share Posted March 25, 2009 Chip, You might want to pose this question to the folks over at NASIOC, http://forums.nasioc.com/forums/index.php?. Oh, they do have a forum specifically for Brakes, Steering & Suspension. My guess is someone has tried it or can give you some specific answer. Link to comment Share on other sites More sharing options...
EVOthis Posted March 25, 2009 Share Posted March 25, 2009 or you could try http://www.clubwrx.net .... I find it extremely hard to believe that the difference between rear drum/disc brakes determines if a Sway bar link will fit or not??..However I could be wrong...the brackets for the links should be in the same spot wheather disc or drum brake...at least on all the Subaru's Ive seen.... Link to comment Share on other sites More sharing options...
