Flywheel compatibility, NA Turbo WRX?
who1981
If you have a 90 legacy then your engine would most likely be an ej22. All n/a legacy have a push type clutch while turbo vehicles, for the most part, have pull type clutches. This means that a 2003 wrx clutch KIT will NOT fit a n/a 90 legacy.
If your car is AWD and it's just the clutch DISK then that might work using your stock flywheel and pressure plate, but be warned the wrx clutch disc is 5mm bigger in diameter than the standard N/A clutch disk; 230mm vs 225mm.
HTH
Kaz
a 2003 wrx clutch KIT {Must acquit! errr...} will NOT fit
Thanks, but I know all about the push'n and pull'n of turbo vs NA EJs. If you read my message you may note that I was inquiring about FLYWHEELS. :grin:
Specifically the ACT StreetLite from a WRX. I just wanted to confirm that it will pop into a 90 NA EJ22 without incident or Mods??? zzz :Flame: I suspect the answer is yes...
Edited by who1981
