Removing trim on 87 gl
the door ding trim i assume? best way to fill 'em is welding them.. i wouldn't want to use bondo, slamming the door might be the best reason for not using it..
possibly fiberglassing? maybe.. still not the greatest bond but fiberglass mat on the inside of the panel with mostly resin to fill in the hole..
painting is required with all listed.. well to atleast look "clean"
