beachbum Posted January 19, 2004 Share Posted January 19, 2004 ok can any1 tell me what the relays are by the coil on a 85 brat 1.8?reason im asking is all my gauges stopped working at the same time and i checked all the wiring and fuses under the dash,so im wondering if those relays have anything to do with it,and the book is no help as to that,if u do know and can help would u let me know what they r in the order of from the passengers fender towards the driver side?so i know which 1 does what? thnx for any and all help (newbie)beachbum Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 19, 2004 Share Posted January 19, 2004 Does it have A/C? My wagon had those relays there - three of em - gold colored right? I pulled em out and tossed em in the garbage.... didn't affect my guages - but then I have a digi-dash. Still - I wouldn't think that would be your problem. GD Link to comment Share on other sites More sharing options...
GLCraig Posted January 19, 2004 Share Posted January 19, 2004 2 questions, Did you check the fues links by the battery? Did you check the ground wire for the instrument cluster, which is hidden by and is above the fuse block? Link to comment Share on other sites More sharing options...
beachbum Posted January 19, 2004 Author Share Posted January 19, 2004 yes i checked the ground wire i didnt even find that until i tried another dash to see if that was it(but to no avail)and yes it does have and works ac,and they r the 3 little gold relays i am talking about also.the reason i thought they might have something to do with it is the temp wire to the block goes into that bunch of wires and also the oil sending unit.keep the suggestions coming and ill keep trying thnx oh yes and p.s i did check the fuse by the coil also. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted January 19, 2004 Share Posted January 19, 2004 Pretty sure from when I was looking that those are either for the A/C, or the Cruise Control - both of which I removed from my wagon. No ill effects to be seen from their removal. I beleive they control such things as the A/C idle up, the A/C fan, and the A/C clutch for the compressor. GD Link to comment Share on other sites More sharing options...
GLCraig Posted January 19, 2004 Share Posted January 19, 2004 Okay I just looked at my wirring diagrams. It looks like everything for the cluster goes through the same position on the IG switch and the same fuse as the coil. So if it starts and runs, your problem is likely between the fuse block and cluster. Link to comment Share on other sites More sharing options...
beachbum Posted January 19, 2004 Author Share Posted January 19, 2004 ok guys after looking at all ur posts(thank u) ive decided with ur help that it is not the relays and after reading GL`s post i`ve decided to try and see if it is my iggy causing the problem.ill try that tomarrow and with any luck ill repost and let u know but dont worry i`ve got a bunch more problems with this truck that im going to need ur help on:D Link to comment Share on other sites More sharing options...
TomRhere Posted January 19, 2004 Share Posted January 19, 2004 http://usmb.net/gallery/albuo81/under_the_hood If you're talking these relays in this pic of my '82, they are for the AC system. Niether my '84 or '86 has them, as theu ae not AC equipped. Thinking you are on the right track in going for the wiring, after the key switch. Possibly, just a bad connection at some point, but I can't say where you'd find it. Link to comment Share on other sites More sharing options...
beachbum Posted January 21, 2004 Author Share Posted January 21, 2004 hey guys just wanted to let u know i checked everything possible and i think its down to the switch wiring and thnx to rick hes sending me 1 to try out.hope it works,but dont worry still going to need alot more help:D Link to comment Share on other sites More sharing options...
