Bkody928 Posted March 28, 2009 Share Posted March 28, 2009 I have just rebuild my 1987 Subaru GL 4wd new timming belts new oil pump put engine at tdc 1 plug but seems like there is no spark new sparks plugs new sparks plug wires, igition coil checked out where it should be what next new distributor cost over $200.00 is that what I need. Help Thank-you bkody928 Link to comment Share on other sites More sharing options...
TomRhere Posted March 28, 2009 Share Posted March 28, 2009 Things to start checking; Check that the T-belt timing is correct. Align the center of the 3 - l l l flywheel marks with the pointer. One cam sprocket dot should be at the top, the other one should be at the bottom. Check disty timing. Put #1 cylinder at TDC. Pull the spark plug and put your finger over the hole, turn engine over with socket on crank pulley bolt until you feel the air pushing on your finger. Then align the timing pointer to "0" on the flywheel. Cylinders: 3----4 1----2 Disty cap; --1-- 3---4 --2-- Rotor should be pointing at #1 plug tower on the cap. Plug wires in proper rotation. Next, re-check the electrical connections for the disty. Make sure they are properly connected. Link to comment Share on other sites More sharing options...
rpholz Posted March 28, 2009 Share Posted March 28, 2009 id have to agree with ^^^^^^ check all of those first and report back frequently for the best amount of help. and kudos on the firing order diagram! lol Link to comment Share on other sites More sharing options...
Cougar Posted March 28, 2009 Share Posted March 28, 2009 Make sure voltage is getting to the plus side of the coil. If there isn't voltage present then check fuse 5 in the dash fuse panel. The horn should work if fuse 5 is okay. Link to comment Share on other sites More sharing options...
