Gloyale Posted April 10, 2009 Share Posted April 10, 2009 Drakien said: I think its a 93-95 legacy with a manual. I got another suggestion from a guy off a local forum, he suggested towing it to a suby dealership and having them write the vin and program it into the ECM. nah........ they wouldn't even be able to do that anymore I don't think. Most of the techs don;t even know how to use the 20 year old select monitor that would be required. Wait, this is OBD II, well anyhow that isn't the solution. also....proabbly dumb question, but did you hook up the large tube under the snorkus that goes to the IAC? And all the other PCV hoses? Connector for the MAF sensor? And lastly the little filter dealy in the vac line that leads to the MAP sensors? Maybe swap it? Link to comment Share on other sites More sharing options...
Drakien Posted April 13, 2009 Author Share Posted April 13, 2009 Sorry for taking so long to respond, I have not been able to work on the car because of work. But Yes that tube is hooked up. There is one small vacuum line that I plugged because every 2.2l engine I have seen has had a screw on plug, so I just stuck a Golf Tee in the line to plug it. It is the one on the top of the passenger side of the manifold. There are 2 places for the small vacuum lines there one above the other. One piece can be removed and have a plug placed in it, but I couldn't loosen the plug from the engine at the Pick and Pull. So I did the Golf Tee. The little filter thingy? Is there a difference between them? Link to comment Share on other sites More sharing options...
Drakien Posted April 13, 2009 Author Share Posted April 13, 2009 Ok I was finally able to make it over to my car, and I did a shot of Starting fluid and it started, then killed. Best part I didn't hear a rod knock! http://www.youtube.com/watch?v=-xmiInQ_V4M Link to comment Share on other sites More sharing options...
Drakien Posted April 18, 2009 Author Share Posted April 18, 2009 Alright so I got an OBDII code reader and its throwing 2 codes. P0117 Engine Coolant Temp Circuit Low Input P0115 Engine Coolant Temp Circuit Malfunction That shouldn't cause it to not start should it? Link to comment Share on other sites More sharing options...
Gloyale Posted April 24, 2009 Share Posted April 24, 2009 Drakien said: Alright so I got an OBDII code reader and its throwing 2 codes. P0117 Engine Coolant Temp Circuit Low Input P0115 Engine Coolant Temp Circuit Malfunction That shouldn't cause it to not start should it? It can. Ussually they won't start when hot. But if the engine doesn't have a proper temp reading, it can have a hard time getting the right mixture to fire. Try simply unplugging it, that will make it default to a fairly rich setting and should fire if the CTS is the problem. Just for posterity I will mention to check that the fuel supply line is hooked up to the correct tube. Foward most, and on top. NOT the one coming out of the pressure regulator. Link to comment Share on other sites More sharing options...
Drakien Posted April 24, 2009 Author Share Posted April 24, 2009 Alright I will try that first thing in the morning! The fuel line coming from the fuel filter is going to the top line on the manifold. Link to comment Share on other sites More sharing options...
Drakien Posted April 24, 2009 Author Share Posted April 24, 2009 Ok so I got off work an hour early so I ran over and tried it out. I unplugged it and it still didn't make any difference. I am debating just saving up and trying to get another 2.5l motor. I just cant get this one to work. Link to comment Share on other sites More sharing options...
Cadogan Posted April 24, 2009 Share Posted April 24, 2009 Don't give up yet man, it sounds like your getting close. Double check your vacuum lines. I had a similar problem with my 86 gl wagon not starting except for when shot with ether. Come to find out it was a vacuum line off. I thought i had them all but the obvious is the ones most overlooked. Link to comment Share on other sites More sharing options...
Drakien Posted April 24, 2009 Author Share Posted April 24, 2009 I unhooked the complete intake manifold/intake piping last night, and replugged everything back in, and its no go I want to say clogged injectors. That is the only thing I can think of that would keep it from starting. Everytime I use a shot of Ether I go like this - Link to comment Share on other sites More sharing options...
Drakien Posted April 27, 2009 Author Share Posted April 27, 2009 I don't have the radiator fans in the car. Would that make any difference? When you shoot in a spray of starting fluid, it will start, the kill right after. Since the fans are not plugged in, is it causing it to not complete a circuit and keeping the car from starting/running? I am totally clueless, I am just out on a limb finding things that could possibly be the issue. I am going to try it with the fans tomorrow morning before work. Just to see. I am *Crossing fingers* on this. If that doesn't work then a new fuel filter and fuel pump it is. Link to comment Share on other sites More sharing options...
Drakien Posted April 30, 2009 Author Share Posted April 30, 2009 Alright so I was able to buy myself a 7 Function Digital Multimeter. Tried the #2 injector. Well, either I did something wrong or it is not getting any power. I also swapped the cam sensor. *the only sensor that was still the 2.2l on it. Didn't make any difference. I put a new fuel filter in for preventative maintenance. Link to comment Share on other sites More sharing options...
rendoll911 Posted May 3, 2009 Share Posted May 3, 2009 any progress on the swap? Link to comment Share on other sites More sharing options...
Drakien Posted May 3, 2009 Author Share Posted May 3, 2009 I am going to have a few local Subaru buddies come over and help diagnose it. I am totally lost. But when this is done I could put up a new post with every possible thing that could be wrong with your car if it wont start lol Link to comment Share on other sites More sharing options...
Drakien Posted May 5, 2009 Author Share Posted May 5, 2009 Well I finally did what everyone said I should do. I changed the fuel pump. Still will not start! I am still waiting on my local subi buds to come over and help. Link to comment Share on other sites More sharing options...
Drakien Posted June 2, 2009 Author Share Posted June 2, 2009 Just keeping this updated. Its still sitting on the side of my friends house. I am so boggled. Link to comment Share on other sites More sharing options...
Drakien Posted June 20, 2009 Author Share Posted June 20, 2009 Alright so as it stands right now- The Computer drops the power out with the three main plugs hooked into the Wiring Harness. When we unplug the bottom (the biggest of the three) then we get power to sensors and we get good fuel pressure. Suggestions? Link to comment Share on other sites More sharing options...
Drakien Posted June 21, 2009 Author Share Posted June 21, 2009 A little more in depth explanation of our diagnosis. We started testing the wiring harness for power, and also sensors and injectors for resistance. Injectors and sensors all had the resistance stated in the Repair Manual. This is where it gets mind boggling. There are 3 main plugs that go into the wiring harness for the manifold and everything hooked to it. The top plug (smallest), middle plug (middle sized), and the bottom (Largest). With all the plugs in we tested the sensors to see if they were receiving a signal. They were not. We unplugged the bottom plug, and we started getting signals to the injectors and sensors. We also got fuel pressure, but with that bottom plug plugged in, we had no power anywhere. We went over the wiring Schematics over and over for both the 2.2 and the 2.5 and came up empty handed. With all 3 plugs in we tested straight from the pin-out of the computer, and no power. But with that bottom plug un-plugged we got power at the computer. We decided to unplug every sensor and anything that plugged in passed the 3 main plugs, one by one, to see if we would find the culprit. We unplugged everything except 3 things with no luck. The 3 things we did not unplug were, One plug under the manifold on the passenger side, it is a blue plug that plugs into a little box with 2 or 3 small vacuum lines coming out of it, and then also the ground that is bolted under the manifold to the block, and last is the engine coolant temp sensor. What we are guessing is that something is telling the computer something it does not like, or something is not completing a circuit. We have no idea what the something is, but it is definitely something electrical and not fuel related. Link to comment Share on other sites More sharing options...
Gloyale Posted June 24, 2009 Share Posted June 24, 2009 Unbolt that ground bolt, clean it, and reconnect. Beyond that, is it possible that there is a short in the engine harness? have you tried a different engine harness? Link to comment Share on other sites More sharing options...
Drakien Posted June 24, 2009 Author Share Posted June 24, 2009 I will do the ground in a little bit and get back with you on that. There is a possibility of having a short. I have not tried a different harness yet. I was thinking about doing that. The ground you are talking about is the one that hooks to the tranny bolt? Link to comment Share on other sites More sharing options...
Drakien Posted June 24, 2009 Author Share Posted June 24, 2009 (edited) Alright I checked the grounds. The one on the tranny seems fine and is clear of any debrie or buildup. Also the one on the drivers side under the manifold is good.Then also the ground at the front of the manifold is also grounded well. Edited June 24, 2009 by Drakien Link to comment Share on other sites More sharing options...
Drakien Posted July 3, 2009 Author Share Posted July 3, 2009 Ok so that bottom plug has power for injectors, and then also all the relays. I hear a clicking when I turn the motor over. Is it possible I have a bad relay causing it to not start? :-\ Link to comment Share on other sites More sharing options...
Drakien Posted July 30, 2009 Author Share Posted July 30, 2009 Alright So I am going to cheat. I am going to just get a wagon with a 2.2l in it with a bad tranny for $700. It drives but it comes out of gear under acceleration or at speeds over 55mph. So The engine runs!! I will swap over anything I need from it. I will make a progress thread in a different section. Thanks everyone for all your assistance with everything! Link to comment Share on other sites More sharing options...
Drakien Posted August 18, 2009 Author Share Posted August 18, 2009 swapped over the wiring harness and bam it started right up. Thanks everyone for all your help~!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
cmiller Posted August 18, 2009 Share Posted August 18, 2009 :banana: Link to comment Share on other sites More sharing options...
