DarkDave Posted May 12, 2009 Author Share Posted May 12, 2009 reposted Link to comment Share on other sites More sharing options...
DarkDave Posted May 12, 2009 Author Share Posted May 12, 2009 How would I FIX this rust in the wheel well??? Link to comment Share on other sites More sharing options...
DarkDave Posted May 12, 2009 Author Share Posted May 12, 2009 Just want to put this up my $600 wagon! Link to comment Share on other sites More sharing options...
edrach Posted May 13, 2009 Share Posted May 13, 2009 Pic are up the ones on the rust inthe rearwell and shock tower.Good luck with getting those bolts out to replace the shock. Soak them good with a decent rust penetrant for about a week. The bolts entend through the threaded portion about a half inch...soak them from that side. And take it slow and easy when you remove them. Link to comment Share on other sites More sharing options...
DarkDave Posted May 14, 2009 Author Share Posted May 14, 2009 edrach, Is wd40 good or should I use something else?? and what about the rust should I cut it out and use sheetmetal? Most of the shock tower is gone to, should I try to rebuild the tower? Link to comment Share on other sites More sharing options...
subyrally Posted May 14, 2009 Share Posted May 14, 2009 edrach,Is wd40 good or should I use something else?? and what about the rust should I cut it out and use sheetmetal? Most of the shock tower is gone to, should I try to rebuild the tower? wd-40 is crap unless you are trying to dry stuff. use PB Blaster or seafoam deep creek. both are great for what you will be needing. they can be found at just abou8t any auto parts store. Link to comment Share on other sites More sharing options...
hatchsub Posted May 14, 2009 Share Posted May 14, 2009 PB-blaster is better than WD40 by far. Link to comment Share on other sites More sharing options...
bheinen74 Posted May 14, 2009 Share Posted May 14, 2009 (edited) How would I FIX this rust in the wheel well??? with my parts Brat i just got, its super clean in the shock support wheel wells, see my 82 Brat GL partout pics link. I am in Iowa so this could end up a easy project. The front and rockers on my BRAT are gone, but the bed, is super solid. Edited May 14, 2009 by bheinen74 Link to comment Share on other sites More sharing options...
