mountaingoatgruff Posted March 29, 2009 Share Posted March 29, 2009 i'm trying to replace the front axles on my wife's 97 OBS and the pass side axle is stuck in the hub. the driver side was rusted and difficult, but the pass is not going anywhere. so far i've tried deep creep, liquid wrench, a propane torch, a 3 jaw puller, a 3lb dead blow mallet, and a 5lb iron sledge but i'm not making any progress - in fact the end of the axle is mushrooming... ideas? Link to comment Share on other sites More sharing options...
Mugs Posted March 29, 2009 Share Posted March 29, 2009 Try bolting everything back up to creat a solid platform. Of course leave the tranny side of the axle out and then pound away at the bugger. I would reccomend wrapping the lug nuts in something like duct tape to prevent the accidental hit to them that could cause dammage. If that does not work, what I have done in some cases is put the axle back into the tranny, then un bolted eveything in order to remove the hub (bungy cord the calipers up and out of the way). Once the hub is able to just hang from the front cv joint I have hit the hub in the flattest part that is not the bearing area and "popped" the axle apart from the inside of the boot (basiaclly the joint comes off the internal snap ring) then I cut away the boot to be able to get the hub free and over to a vise or press. I then proceed to hammer on the axle using the vise as a platform to lay the hub flat, the same goes for a press but instead I press the axle out...but not everybody has access to a press. Once the cv part of the axle is out then I take out the DOJ part of the axle from the tranny, and put everything pack together, and of course I apply a light layer of grease to the splines and hub as well before going back in. Hope this helps Link to comment Share on other sites More sharing options...
msmithmmx Posted March 29, 2009 Share Posted March 29, 2009 Had some what of the same issue. While someone is grabing the knuckle and pulling away ffrom the car take a dead blow hammer pound the hell of the end of the axle where the nut would go. Watch out for your helpers head and jaw Link to comment Share on other sites More sharing options...
Gloyale Posted March 29, 2009 Share Posted March 29, 2009 I recently did a forrester where I had to remove the whole knuckle and put it on the press. Except my 8 ton press in the shop didn't work. I had to take it to thte machine shop and have them use there 20 ton press:eek: Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 29, 2009 Author Share Posted March 29, 2009 thanks for the replies, folks. i have the trans out, and the knuckle on the car. i disassembled the doj so i could get the trans back in and still wail on the axle if necessary. makes it a bit easier to hammer too. i have access to a 12 ton press, so i'll just have to remove the whole mess and see what happens. i've been trying to avoid doing that cuz i've read that those knuckles can be warped easily (i think i read that about changing wheel bearings). Link to comment Share on other sites More sharing options...
Gloyale Posted March 29, 2009 Share Posted March 29, 2009 mountaingoatgruff said: i've been trying to avoid doing that cuz i've read that those knuckles can be warped easily (i think i read that about changing wheel bearings). Brace it on the press bridges using the the strut mount and ball joint mount sections. Don't try to brace it against the brake mount area. You'll need to add a 3/4 inch bar under the balljoint area to level it with the strut mount Link to comment Share on other sites More sharing options...
subaru360 Posted March 29, 2009 Share Posted March 29, 2009 I had one like that last week. I spent an hour beating on it with a 5lb sledge and soaking it with pb blaster. It finally let loose and came out. No fun. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 30, 2009 Author Share Posted March 30, 2009 spent 2 hours with an oxy-acetylene torch, p'blaster and a 12 ton press and its still stuck. i could see the knuckle literally bending under the pressure but the axle would not come loose! my dad insisted on trying some more tomorrow, he's going to try cutting the back of the cv off then drilling the splined shaft to see if it will loosen up. guess i'm getting another knuckle... Link to comment Share on other sites More sharing options...
pearlm30 Posted March 30, 2009 Share Posted March 30, 2009 Good luck with it, I never seen anything like that either. I was about to suggest axle tool but I dont think it can beat the 12 ton press:eek: mountaingoatgruff said: spent 2 hours with an oxy-acetylene torch, p'blaster and a 12 ton press and its still stuck. i could see the knuckle literally bending under the pressure but the axle would not come loose! my dad insisted on trying some more tomorrow, he's going to try cutting the back of the cv off then drilling the splined shaft to see if it will loosen up. guess i'm getting another knuckle... Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted March 30, 2009 Author Share Posted March 30, 2009 anyone know if will my brakes work safely if i unplug the abs computer and throw the non-abs 93 knuckes on there? the 93 knuckles have brand new bearings and ball joints begging to be used. Link to comment Share on other sites More sharing options...
ericem Posted March 30, 2009 Share Posted March 30, 2009 The brakes will be just fine as long as you Don't mind no abs. Link to comment Share on other sites More sharing options...
subaru360 Posted March 30, 2009 Share Posted March 30, 2009 mountaingoatgruff said: anyone know if will my brakes work safely if i unplug the abs computer and throw the non-abs 93 knuckes on there? the 93 knuckles have brand new bearings and ball joints begging to be used. Yes they will work fine. Unplug the abs and take the bulb out on the dash. Link to comment Share on other sites More sharing options...
frag Posted March 30, 2009 Share Posted March 30, 2009 If you have an air compressor you could try a pneumatic hammer (size of an air drill and relatively cheap) I've succeeded removing very stuch things with that. It gives very rapid and sharp blows that can free almost anything. Link to comment Share on other sites More sharing options...
