yeah you have to pull (ther) pins holding the ends on then (shorted) each end about a inch then you have to shorten the inside of the end caps (fluch) to the inside then (dril) new holes for the tiny pins and re (asemble) and dont forget to preload the spring so it will retract
your slurring your type.. you need more sleep dude, looks sweet though
