susman Posted March 29, 2009 Share Posted March 29, 2009 (edited) I want to turn a automatic sus into a 5 speed Will a 95 subaru legacy 2.2 manual transmission match up to a 99 subaru legacy sus 2.5 engine to replace the automatic transmission I know the pedals and clutch will have to be installed but can that engine even have a manual transmission Edited March 29, 2009 by susman Link to comment Share on other sites More sharing options...
Lazer Posted March 29, 2009 Share Posted March 29, 2009 Yes it will fit.. no problem there. Link to comment Share on other sites More sharing options...
Battlewagon Posted March 29, 2009 Share Posted March 29, 2009 It'll fit........ but, you'll have to modifiy (or change) your ECU so it understands that you have a manual. Plus you'll need a manual crossmember and of course clutch, flywheel, pedals and shifter linkage. Here is a write up for you: http://www.legacycentral.org/library/transmission/convert.htm But that is just tiddly bits; the transmission will fit up nicely. Link to comment Share on other sites More sharing options...
idosubaru Posted March 30, 2009 Share Posted March 30, 2009 the 99 bellhousing bolt pattern is different, but it can work. you just won't use all the holes, just use the ones that line up. i think that means you'll have only one nut/bolt holding the starter in place instead of two unless you make the second fitment point. everything else will be simple. buying a donor car is much simpler than piecing this together. make sure the clutch components all come from the type of clutch you want - hydraulic or cable clutch. the higher end cars got hydraulic clutches starting the mid 90's like GT's and others. Link to comment Share on other sites More sharing options...
Gloyale Posted March 30, 2009 Share Posted March 30, 2009 grossgary said: the 99 bellhousing bolt pattern is different, but it can work. you just won't use all the holes, just use the ones that line up. i think that means you'll have only one nut/bolt holding the starterin place instead of two unless you make the second fitment point. This is a misconcetption. The lower starter bolt is a stud set into the bellhousing. Just like EVERY subaru since 1980. The pre 98 trans will bolt perfectly to the post 98 engines, and vice versa. Upper starter bolt is an engine to trans bolt, but the lower starter bolt is NOT part of the engine to trans mounting. I am not sure where this misconception started, but it needs to stop. It makes it seem as if there is some *probblem* bolting old and new engines and trans toghether. There is not. Link to comment Share on other sites More sharing options...
subaru360 Posted April 6, 2009 Share Posted April 6, 2009 Gloyale said: This is a misconcetption. The lower starter bolt is a stud set into the bellhousing. Just like EVERY subaru since 1980. The pre 98 trans will bolt perfectly to the post 98 engines, and vice versa. Upper starter bolt is an engine to trans bolt, but the lower starter bolt is NOT part of the engine to trans mounting. I am not sure where this misconception started, but it needs to stop. It makes it seem as if there is some *probblem* bolting old and new engines and trans toghether. There is not. X2 every manual trans will have the lower starter stud. Add the matching rear diff to the list of parts needed. The sus will have 4.444 rear diff, so you will need a diff with a ratio to match the new trans. Link to comment Share on other sites More sharing options...
wabenzibx Posted June 10, 2010 Share Posted June 10, 2010 I have a 1999 Subaru Legacy Outback with a 2.2L and a 5 speed. The 1999 tranny is hard and expensive to find. Does ayone know what will bolt in its place. Also I heas that TY752VACCA and/or TY52V2DCA might work but that the reverse is different. Whats different about it. Will it still bolt in and work? Thanks in advance to anyone that can help. Link to comment Share on other sites More sharing options...
newsoobdude Posted June 11, 2010 Share Posted June 11, 2010 +2 on the matching diff. If I remember correctly my 98 with 5mt is a 4.11:1. What are going to be using the car for as you might just consider going with the 88/89 D/r 5spd and a 3.9 diff if you are going to be going wheeling a lot and want a low range. I cannot wait til I can afford the Down Under D/r instead of going the 89 D/r swap as I am already a manual trans and don't want to change out my rear diff and hydraulic clutch as well. Link to comment Share on other sites More sharing options...
MWNW Posted April 9, 2017 Share Posted April 9, 2017 On 3/30/2009 at 3:43 PM, Gloyale said: This is a misconcetption. The lower starter bolt is a stud set into the bellhousing. Just like EVERY subaru since 1980. The pre 98 trans will bolt perfectly to the post 98 engines, and vice versa. Upper starter bolt is an engine to trans bolt, but the lower starter bolt is NOT part of the engine to trans mounting. I am not sure where this misconception started, but it needs to stop. It makes it seem as if there is some *probblem* bolting old and new engines and trans toghether. There is not. This is not correct. The lower starter bolt is a stud set into the bellhousing only for automatic transmissions. Not true for manual. Link to comment Share on other sites More sharing options...
Numbchux Posted April 10, 2017 Share Posted April 10, 2017 (edited) On 4/9/2017 at 4:33 PM, MWNW said: This is not correct. The lower starter bolt is a stud set into the bellhousing only for automatic transmissions. Not true for manual. Welcome, and I do have to give you credit for searching. But digging up a ~7 year old thread to make a small correction (which isn't really correct, as it's only true of the 8 bolt manuals, the 4 bolt ones did have a stud) is not really necessary.... Edited April 10, 2017 by Numbchux Link to comment Share on other sites More sharing options...
