went wheelin for the first time
The Scooby
whats the story here
I decided that getting stuck might not be so bad. It half way looked like I'd be able to get back up before I got down in the creek. We've had to winch my little buddy B's land cruiser out of that hole. He has 35 inch boggers.
Truth being, I was missing my Toy right about there. The winch is a lot less work than the come a long. I broke one of them. In the end, I got it out, then high centered it on a log. (one that's also got B's rig stuck on) It was a quick tug wiht the come a long again. Fun stuff.
i had a freaking BLAST, i am so amazed how easily my car did everything i wanted it to do, from the hill climb to just getting over the fallen logs and such.
i know im still a noob at wheelin but i learned alot about clutch and brake control as well as planning your line as you go. another neat thing i learned was that if i need to make a tight turn just put in 2wd and pop the clutch and i can easily swing the front end around to where i want to go or same with the back with the help of a log.
im REALLY looking forward to the evans creek meet and making a run at 311.
with the TSL SSR's and rear LSD there was never a problem with no traction and again the EJ22 performed flawlessly even when i dunked the front end into the creek to the hood and drove through it.
