subiemech85 Posted April 2, 2009 Share Posted April 2, 2009 10" is a common size for hvacr I quickly become when trying to figure out which one I need in regards to cw or ccw best that I can tell it currently has a ccw puller if my figuring is correct :?: HS series HU-1005-40 Unit bearing 40° 1.125" 3.25" 3600 rpm data table http://www.airdrive.com/5wing_specs2.htm from http://www.airdrive.com/5wing2.htm may work BTW: it's for the '78 BRAT with lone-star air and sanden compressor the old fan keeps breaking little bits off how long do you watch the fan twirl? Link to comment Share on other sites More sharing options...
Kostamojen Posted April 3, 2009 Share Posted April 3, 2009 Are you doing a restoration? If not, I'd ditch that fan assembly and put in a second electric fan that won't fall apart as easily as those do. Link to comment Share on other sites More sharing options...
subiemech85 Posted April 3, 2009 Author Share Posted April 3, 2009 I am in the beginning of a multi-year restoration http://www.theymightberacing.com/Restoration/InSituPlanning.aspx a/c works, fan stays when done, I want it to look like you just stepped off the way back macnine set to 1979 Link to comment Share on other sites More sharing options...
The Dude Abides Posted April 3, 2009 Share Posted April 3, 2009 If you want mine ill swap ya for an electric one in one of your crap wagons. Link to comment Share on other sites More sharing options...
waimaks Posted April 3, 2009 Share Posted April 3, 2009 Over here 4wd EA81s got a standard belt driven fan Link to comment Share on other sites More sharing options...
