greenleg88 Posted April 2, 2009 Share Posted April 2, 2009 what is it that makes cars lose so much power as they age. my car is from 97 and it definitely did not have the same power new. it is definitely much slower from when it was new. how can power be restored? and i dont mean modding it.. i mean just getting it back to what it was like new or close. Link to comment Share on other sites More sharing options...
johnceggleston Posted April 2, 2009 Share Posted April 2, 2009 greenleg88 said: what is it that makes cars lose so much power as they age.my car is from 97 and it definitely did not have the same power new. it is definitely much slower from when it was new. how can power be restored? and i dont mean modding it.. i mean just getting it back to what it was like new or close. ok, it's a 97, is that a ford or chevy? miles, model, trans, recent service, and ... what's it doing wrong?? Link to comment Share on other sites More sharing options...
nipper Posted April 2, 2009 Share Posted April 2, 2009 Why cant a 60 year old man run as fast as a 20 year old. Wear and tear. There are many moving parts the rub eachother and wear over time. If the car is not properly maintained (frequent oil changes) those parts can wear faster. The parts here are valves and more importatntly piston rings. they are required to make compression to make the car go (suck squish boom). The next one which you cna do something about is a tuneup. Then there is other things like performance tires, dragging brakes. nipper Link to comment Share on other sites More sharing options...
shadetreemech Posted April 2, 2009 Share Posted April 2, 2009 I will assume that tuneup issues (timing, spark plugs, air cleaner, fuel delivery) are not present. If you have many miles on the engine, worn piston rings/cylinders and leaky valves will cause lower compression, with loss of power. a compression test will help pinpoint this. If you have blue smoke out the pipe from oil burning, your engine is just worn out. Link to comment Share on other sites More sharing options...
CNY_Dave Posted April 3, 2009 Share Posted April 3, 2009 (edited) To be a little more specific- crud buildup in the intake/exhaust passages and on the valves blocks intake/exhaust flow valves open later, close sooner, and don't open as far as valvetrain components wear valve timing is retarded as the timing belt stretches (Probably only a very small amount) cylinder compression goes down as the cylinder and rings wear the fuel injector spray becomes less fine and even as crud builds up on the internal injector parts, and as the injector bits wear against each other. The muffler could be plugging up (not a frequent occurrence) The oxygen sensors could be a little out of spec, giving not quite the right mixture. The mass-airflow sensor could be a bit off, not sure if that is common on subes. The throttle-position sensor could be out-of-spec. the catalytic converter(s) could be somewhat blocked. If any of those last 4 go far enough out-of-spec it'll throw a code. Dave Edited April 3, 2009 by CNY_Dave Link to comment Share on other sites More sharing options...
greenleg88 Posted April 5, 2009 Author Share Posted April 5, 2009 johnceggleston said: ok, it's a 97, is that a ford or chevy? miles, model, trans, recent service, and ... what's it doing wrong?? sorrry. its a 97 legacy L. automatic and just hit 157k its not doing anything wrong. its just old and slow.. but i dont know what it is about being old that makes care lose so much power. i just heard of leaking past pistons but i dont really know much else. miles airfilter - 10 k fuel filter - 3k spark plugs/wires- 10k oil - 800 miles its definitely running smoother than when i got it first.. but im just wondering about the loss of power over the years. and thanks for the all the answers Link to comment Share on other sites More sharing options...
greenleg88 Posted April 5, 2009 Author Share Posted April 5, 2009 oh yeah. the CEL does come on occasionally for the throttle pos sensor. and by occasionally i mean twice in the last year. it goes away by itself so far. its really strange.. it will be there and then maybe after 12 hours or so or just the next time i start my car its gone. i unplugged it blew out any dust... i was thinking maybe it just had a bad connection or something. im not sure what the code is about... its never consistently there. what should i do about that? Link to comment Share on other sites More sharing options...
uniberp Posted April 6, 2009 Share Posted April 6, 2009 greenleg88 said: sorrry. its a 97 legacy L. automatic and just hit 157k its not doing anything wrong. its just old and slow.. but i dont know what it is about being old that makes care lose so much power. i just heard of leaking past pistons but i dont really know much else. miles airfilter - 10 k fuel filter - 3k spark plugs/wires- 10k oil - 800 miles its definitely running smoother than when i got it first.. but im just wondering about the loss of power over the years. and thanks for the all the answers An occasional can of Techron injector cleaner will perk it up. I like the list posted above, and I'd put bad injector spray at the top. When that happens, and it does, excess carbon accumulates and causes wear and stuff. New plug wires I recommend, because those seriously degrade at that mileage. There are many opinions about plug wires, but high quality silicone aftermarket ones are avialable, IMO. Blue NGK. Link to comment Share on other sites More sharing options...
greenleg88 Posted April 14, 2009 Author Share Posted April 14, 2009 what is the difference in all the different spark plug wires... as long as they consistently conduct the spark, isnt that good enough? what more could they do... Link to comment Share on other sites More sharing options...
Cougar Posted April 14, 2009 Share Posted April 14, 2009 greenleg88 said: what is the difference in all the different spark plug wires... as long as they consistently conduct the spark, isnt that good enough? what more could they do... Some wires are better quality than others and the better ones let the spark plugs work better. Through trial and error, most here feel that OEM parts are the best way to go and give the least trouble. NGK rules. Link to comment Share on other sites More sharing options...
OB99W Posted April 14, 2009 Share Posted April 14, 2009 Yes, spark plug wires have to conduct properly. They also have to not ''leak'' voltage before it gets to the plug. You might be surprised how many plug wires fail at one or the other task. Link to comment Share on other sites More sharing options...
nipper Posted April 14, 2009 Share Posted April 14, 2009 greenleg88 said: what is the difference in all the different spark plug wires... as long as they consistently conduct the spark, isnt that good enough? what more could they do... There is much more to a spark plug wire then conducting spark. They have to contain 100,000 volts or more. They must be shielded from induced voltages from other wires (not a big issue on a sooby). They must deal with engine oil and under hood temps of 300 degrees or higher. They also must assist in keeping ingnition noise from showing up over the radio. Wires are made of silicon insulation. Poor quality silicon (read cheap wires) will quickly break down under the stress of high voltage and engine temps and allow for voltage leakage. Wire trees are used to keep wires from inducing spark in its neighboor wires. http://www.generalcable.com/NR/rdonlyres/F3629AA7-1B9E-40E6-A74B-4D3949CD1B9B/0/AUT_0060_1002.pdf Skip the part where they are saying thier product is the best but thier points are valid in wire construction. Link to comment Share on other sites More sharing options...
erik litchy Posted April 15, 2009 Share Posted April 15, 2009 i always like the http://en.wikipedia.org/wiki/Italian_tuneup Link to comment Share on other sites More sharing options...
zyewdall Posted April 15, 2009 Share Posted April 15, 2009 Have you changed the transmission fluid recently? If it's the original, it might help a little. Z Link to comment Share on other sites More sharing options...
greenleg88 Posted April 16, 2009 Author Share Posted April 16, 2009 zyewdall said: Have you changed the transmission fluid recently? If it's the original, it might help a little. Z yup i did it.. and then i had to get an mpt clutch changed? which was done at the dealership so im assuming the fluid was drained and refilled then too... Link to comment Share on other sites More sharing options...
greenleg88 Posted April 16, 2009 Author Share Posted April 16, 2009 so when i first got the car... it did 3500 miles fine... and then for about 900 miles, it leaked and i mean leaked a quart of oil every 300 miles.. but somehow that some how fixed itself.. i dont know how... or why.. but thers no smoke from dripping on the exhaust anymore and ive just been reading about seafoam and how it can take out carbon buildup and cause high mileage engines to lose compression.. and perhaps clean out any thing that was clogging up potential oil leaks. does techron have a similar effect? do you think that is what caused my car to start pouring a quart of oil every 300 miles...? Link to comment Share on other sites More sharing options...
Olnick Posted April 16, 2009 Share Posted April 16, 2009 uniberp said: An occasional can of Techron injector cleaner will perk it up. I'd suggest the Techron Concentrate rather than their injector cleaner. I'm not a big fan of additives but I do believe in that stuff. A bottle in the gas tank every 6 months really makes the old '95 EJ22 smile. Link to comment Share on other sites More sharing options...
Olnick Posted April 16, 2009 Share Posted April 16, 2009 greenleg88 said: does techron have a similar effect? do you think that is what caused my car to start pouring a quart of oil every 300 miles...? Nope, Techron won't have any effect on your oil. You might want to replace your PCV valve and clean the hose leading to it, that may help. Link to comment Share on other sites More sharing options...
greenleg88 Posted April 16, 2009 Author Share Posted April 16, 2009 Olnick said: Nope, Techron won't have any effect on your oil. You might want to replace your PCV valve and clean the hose leading to it, that may help. hm its about 10k miles old.. and how would that help? isnt that just about recirculating air or something.. i dont realyl know what it does. Link to comment Share on other sites More sharing options...
Olnick Posted April 16, 2009 Share Posted April 16, 2009 greenleg88 said: hm its about 10k miles old.. and how would that help? isnt that just about recirculating air or something.. i dont realyl know what it does. Yeah, it recirculates air--and all the crap in it from the crankcase. Try pull the PCV and the hose and flush them out with an aerosol spray, I think you'll be happy you did! Link to comment Share on other sites More sharing options...
Gloyale Posted April 16, 2009 Share Posted April 16, 2009 nipper said: There is much more to a spark plug wire then conducting spark. They have to contain 100,000 volts or more. They must be shielded from induced voltages from other wires (not a big issue on a sooby). They must deal with engine oil and under hood temps of 300 degrees or higher. They also must assist in keeping ingnition noise from showing up over the radio. Wires are made of silicon insulation. Poor quality silicon (read cheap wires) will quickly break down under the stress of high voltage and engine temps and allow for voltage leakage. Good summary. Additionally they have to conduct those 100,000 volt pulses, with absolutely no *lag* or delay. THOUSANDS OF TIMES PER MINUTE! I'd say that the most common thing I do to restore power to an engine is to clean the carbon off of vavles, and piston crowns. (assuming rings and all else are still decent) I do this every single time I have an engine apart for head gaskets. I set the piston slightly below the deck, and use a wire wheel on the end of a drill to clean it's head. Fine, soft bristle, won't scratch the iron cylinder walls, but will ussually get all the carbon. Sometimes I have to take a screwdriver to crevices in valve notches and such. WD-40 aids the process. Link to comment Share on other sites More sharing options...
