mikec03 Posted April 2, 2009 Share Posted April 2, 2009 I have a 1997 2.2 Sub. I'm getting a lot to noise from the motor which may be piston slap or valve misadjustment. Yes it does diminish when the motor is hot but I still am not sure what is causing it. My question: If I take off the valve cover, will I find that the valve adjustment can be done with a wrench and screw driver or does the 97 have solid adjusters that require shims. I'm familiar with the 95's which have hydraulic valve adjusters, which work very well, but Subaru changed after 95. Link to comment Share on other sites More sharing options...
mountaingoatgruff Posted April 2, 2009 Share Posted April 2, 2009 I have a 1997 2.2 Sub. I'm getting a lot to noise from the motor which may be piston slap or valve misadjustment. Yes it does diminish when the motor is hot but I still am not sure what is causing it. My question: If I take off the valve cover, will I find that the valve adjustment can be done with a wrench and screw driver or does the 97 have solid adjusters that require shims. I'm familiar with the 95's which have hydraulic valve adjusters, which work very well, but Subaru changed after 95. 97 2.2 does not require shims to adjust, only tools. Link to comment Share on other sites More sharing options...
