rear brakes 1994 loyale
painter007
hey guy's . I have a 94 loyale wagon 4 wheel drive that I turned into a Brat and swapped the motor to a 2.2. my rear brake drums are worn out and new drums are 167.00 each .can I swap rear brakes from a 92 legacy. as there are some legacy's at my local auto wreckers no loyales.please help.thanks
not really, no. if you were swapping to 5-lug, you could use XT6 hubs, and then modify the legacy backing plates to mount to the loyale trailing arms, and then use the legacy rotors and calipers.
but if you're staying 4-lug, just grab an EA82t rear disc setup. they usually sell here for much less than those new drums.
Thanks for the info. do you know if the front hubs of a loyale fit the back axle shafts .I have no problem in making brackets to mount the caliper.I have done some chevy disc brake on ford rear end for street rods in the past.
