painter007 Posted April 3, 2009 Share Posted April 3, 2009 hey guy's . I have a 94 loyale wagon 4 wheel drive that I turned into a Brat and swapped the motor to a 2.2. my rear brake drums are worn out and new drums are 167.00 each .can I swap rear brakes from a 92 legacy. as there are some legacy's at my local auto wreckers no loyales.please help.thanks Link to comment Share on other sites More sharing options...
Numbchux Posted April 3, 2009 Share Posted April 3, 2009 not really, no. if you were swapping to 5-lug, you could use XT6 hubs, and then modify the legacy backing plates to mount to the loyale trailing arms, and then use the legacy rotors and calipers. but if you're staying 4-lug, just grab an EA82t rear disc setup. they usually sell here for much less than those new drums. Link to comment Share on other sites More sharing options...
painter007 Posted April 3, 2009 Author Share Posted April 3, 2009 Thanks for the info. do you know if the front hubs of a loyale fit the back axle shafts .I have no problem in making brackets to mount the caliper.I have done some chevy disc brake on ford rear end for street rods in the past. Link to comment Share on other sites More sharing options...
Numbchux Posted April 3, 2009 Share Posted April 3, 2009 they won't. although even if they did, I don't know how that would help.... Link to comment Share on other sites More sharing options...
Turbone Posted April 5, 2009 Share Posted April 5, 2009 Posting in the Wanted Forum for rear disc's or drums might get better results. Link to comment Share on other sites More sharing options...
Quidam Posted April 5, 2009 Share Posted April 5, 2009 Hi, Last time I checked, I could buy new rear drums to fit your car, for about $50.00 ea. Rock Auto. Closeout. So that's much less than the price you got. Just putting out another option. Doug Link to comment Share on other sites More sharing options...
painter007 Posted April 5, 2009 Author Share Posted April 5, 2009 Thanks guys for the info. Link to comment Share on other sites More sharing options...
painter007 Posted April 11, 2009 Author Share Posted April 11, 2009 hey guys I found a 1986 GL10 4 WHEEL drive,it has rear disc brakes.will these fit my 94 loyale . Link to comment Share on other sites More sharing options...
Numbchux Posted April 11, 2009 Share Posted April 11, 2009 yessir:) Link to comment Share on other sites More sharing options...
