tailgatewagon Posted January 20, 2004 Share Posted January 20, 2004 ok a cuple of intercooler questions first is there a formula for figureing optimum intercooler size. secound can you put to big an intercooler on. will performance drop if its to big or wil flow become a problem?? im thinkin of this set up. ea82T wrx turbo. new crossover and down pipe. bost contorler to run 12-15lbs intercooler fo course. spider intake. let me know what you think. Link to comment Share on other sites More sharing options...
Dr. RX Posted January 20, 2004 Share Posted January 20, 2004 Yes there is a formula for figuring out the size of the I/C, but I can't remember it, it is in one of my books around here somewhere. The problem with using a WRX turbo is that it doesn't have the ability to attach the 90 degree angle piece that you need to an EA82T. Make sure that you find a turbo spyder intake, or have access to a machine shop to modify the N/A intake. If you can find an I/C for a 1800cc to 2200cc engine you should be pretty close with the right size I/C. The real thing to look for is how the I/C is plumbed (where the inlet and outlet are located), some may not work with teh Subaru layout. Link to comment Share on other sites More sharing options...
