Strange Noise After Engine Swap
Well I replaced a 2000 2.5 SOHC in my Forester with the same engine except it's a 2004. Everything went well, it runs fine but there is a noise I don't remember hearing before. It is kind of a low humming sound, it is NOT rpm or even engine related because I can get the sound briefly with the engine off. After turning the key to on position it happens for a few seconds then stops. While the engine is running it is continuous, same pitch, same volume.
Does the fuel pump sound like a possibility?
I can't see how a swap would cause any change in the fuel delivery system, maybe it was always there and I'm listening more closely now... Any ideas? Thanks
Sounds like maybe ABS or fuel pump. Did you try to pull the ABS fuse(s)? I would imagine that you could pull the fuel pump fuse as well while the car is running, it should run for at least a second or two... maybe...
