bigo1966 Posted April 8, 2009 Share Posted April 8, 2009 Cut the rear fenders so much they took about 1" off the door? Link to comment Share on other sites More sharing options...
Uberoo Posted April 8, 2009 Share Posted April 8, 2009 it could be done but then the door wouldnt latch,because you would have cut the latch out. it could be done if you were willing to cut and reweld the door latch (and fender) to the new location. the edge of the door is at the inner fender edge... Link to comment Share on other sites More sharing options...
one eye Posted April 8, 2009 Share Posted April 8, 2009 I'm real close to an inch I just rolled it under to make a smoothe place in case the tire rubbed Jeff Link to comment Share on other sites More sharing options...
bigo1966 Posted April 8, 2009 Author Share Posted April 8, 2009 Cool thanks, if im going to fit 32"s im going to have to trim my door.....and ALOT of firewall. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 8, 2009 Share Posted April 8, 2009 McBrat has 35's and he did not cut doors Link to comment Share on other sites More sharing options...
one eye Posted April 8, 2009 Share Posted April 8, 2009 Wow 32's Eah? Make sure you don't get an offset that is to far out.....you'll never turn again if you do. Mine rub to the point where it gobbles up the tire in a sharp turn, and I can't turn back............ just for a heads up..................... Jeff Link to comment Share on other sites More sharing options...
one eye Posted April 8, 2009 Share Posted April 8, 2009 McBrat has 35's and he did not cut doors But he has about 20" of lift....................If he'd have done it on a wagon I'm sure things would be a bit different. Jeff Link to comment Share on other sites More sharing options...
bigo1966 Posted April 9, 2009 Author Share Posted April 9, 2009 Where it starts gobbling up the tire im going to cut out move back and reweld......i hope. I do have a decent offset and it really makes things worse. Link to comment Share on other sites More sharing options...
The Scooby Posted April 9, 2009 Share Posted April 9, 2009 may i ask what engine and tranny you are going to run with 32"s if its still the stock engine and specifically gearing all you are gonna do is burn up clutches. the tires are too big and will overcome the gearing and basically it will be for looks and a pain to drive epically off road. Link to comment Share on other sites More sharing options...
ivantruckman Posted April 9, 2009 Share Posted April 9, 2009 Just start off in low 4x4 run 33,s (if you have a dual range) Link to comment Share on other sites More sharing options...
bratman18 Posted April 9, 2009 Share Posted April 9, 2009 I still don't understand how any one runs such huge tires on stock drive train! My Brat has 26's on it and it is def starved for power and is hard on the clutch Link to comment Share on other sites More sharing options...
The Scooby Posted April 9, 2009 Share Posted April 9, 2009 ya i dont know how well my stock EA82 clutch will do with the EJ and my 27inch SSR's Link to comment Share on other sites More sharing options...
one eye Posted April 10, 2009 Share Posted April 10, 2009 I've had 30s on a few of my rigs and had no problems. Just don't ride the hell out of your clutch and you should be fine, and if its carbed run a weber. I think you could run 32s, the beast I drive, Bill has has 31's so one more inch aint going to be much more. How much lift do you have? Jeff Link to comment Share on other sites More sharing options...
bigo1966 Posted April 10, 2009 Author Share Posted April 10, 2009 I roughly have 5" of lift. The plan to acheive the gearing to turn 32's is stuff a motorcycle engine and transmission under the hood, mated to the subaru d/r. Use the subaru clutch still. It will take some work but it will be worth it...and fun. Link to comment Share on other sites More sharing options...
3eyedwagon Posted April 11, 2009 Share Posted April 11, 2009 I still don't understand how any one runs such huge tires on stock drive train! My Brat has 26's on it and it is def starved for power and is hard on the clutch We all must have magical clutches! Just drop it, and go, and you shouldn't have that much of a problem. As for this thread: Good idea! I can't wait to see how it turns out. Link to comment Share on other sites More sharing options...
ivantruckman Posted April 13, 2009 Share Posted April 13, 2009 i trimmed just about an inch to get 215 60 15 /s under . without a lift, the shocks were on the highest peg [ATTACH][/ATTACH] Link to comment Share on other sites More sharing options...
