rtcaravan Posted April 8, 2009 Share Posted April 8, 2009 91 legacy has miss in #3 cyl. new plugs and wires. plug is not wet andi have spark but it don't look strong. were there any known coil problems. it has about 160,000 an it. Link to comment Share on other sites More sharing options...
DaveT Posted April 9, 2009 Share Posted April 9, 2009 I have not had a bad coil. All but one of my EA82s have been run to 160K-205K miles. Years ago, I went to do a compression test on my 86. So I did what I always had, remove the plugs, unhook the high tension wire from the top of the coil. When I hit the starter for the first test, the arc jumped right up and out of the coil to the nearest screw terminal. So a normal working coil can throw an arc over 1" long. Link to comment Share on other sites More sharing options...
rtcaravan Posted April 9, 2009 Author Share Posted April 9, 2009 it ran fine when she shut it off. when she started it back up is when it started missing. Link to comment Share on other sites More sharing options...
rtcaravan Posted April 9, 2009 Author Share Posted April 9, 2009 not an ingition problem. tried a diff coil didn't change, has great compression. has injector pulse at plug but i can't get the injector ouy to check it, any one have any sugestions. Link to comment Share on other sites More sharing options...
Gloyale Posted April 10, 2009 Share Posted April 10, 2009 91 legacy has miss in #3 cyl. new plugs and wires. What type of plugs and wires? Wrong parts on EJ ignition will cause problems. But start by checking that the spark plug wires are as far as possible from the injector wires. Get some of that flexible wiring cover and put it over the section of the wire that runs close. Make sure there are no nicks or cuts in the injector wiring insulaztion. BTW......This should be in the New Generation Forum and may get moved. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 10, 2009 Share Posted April 10, 2009 Replace your plugs with NGK's. And STOP posting in the old gen forum. Go where the knowledge is - NEWER GENERATION. GD Link to comment Share on other sites More sharing options...
rtcaravan Posted April 12, 2009 Author Share Posted April 12, 2009 found the miss fire was a bad injector. must have going bad for a while, runs smoother and has alot more power. thanks for the help guys. Link to comment Share on other sites More sharing options...
