thermalsurfing1 Posted April 9, 2009 Share Posted April 9, 2009 hay everyone i just bought a 1984 Subaru Brat with a automatic tranny that is super clean, no t tops. . I also ordered a 4" lift from sjr a few days ago but i just realized i don't think i can lift it with a automatic tranny. can anyone give advice on this. i do have a 4 speed hi lo i can swap with the shifter extended but i don't think a can do the clutch swap. so can i use my automatic or do i have to swap it. Link to comment Share on other sites More sharing options...
P K Posted April 9, 2009 Share Posted April 9, 2009 You can lift an auto trans Brat. Uses the same kit, but should probably have four (4) more lift blocks for the auto trans crossmember. (been so long I cant remember) Talk to Scott at SJR, great guy, he'll hook you up. You may want the 4 or 5 speed later on anyway. Quite a lot more to it though > You will need a flywheel ($90) make sure you get the larger 8 7/8 diam version, clutch kit ($180), manual pedal assembly, manual driveshaft, and 3.90 rear diff. Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted April 9, 2009 Share Posted April 9, 2009 I think it will work with your brat being auto the main difference is your auto trans cross member. You can do a manual swap, and it really isn't all that bad. I have a '84 ea81t coupe that started out life as an auto but soon grew into its 5 speed d/r trans thanks to Jerry's kit. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 9, 2009 Share Posted April 9, 2009 The swap isn't that hard. It's is worth every minute of work. You can get a flywheel from a board member for cheap. I may have one laying around...they are shippable through a $13 flat rate box. The auto trans is iffy in a stock Brat, you put a lift on it, you'll want bigger tires and that means the auto trans is less than desirable. Link to comment Share on other sites More sharing options...
thermalsurfing1 Posted April 9, 2009 Author Share Posted April 9, 2009 (edited) thanks for the reply's. i have the flywheel, stage 2 center force clutch all in my doner car. i am going for it. i just installed the weber carb..... wow what a difference ! anyone know where the vacuum line on the auto tranny went, it wont shift right. Edited April 9, 2009 by thermalsurfing1 Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 11, 2009 Share Posted April 11, 2009 thanks for the reply's. i have the flywheel, stage 2 center force clutch all in my doner car. i am going for it. i just installed the weber carb..... wow what a difference ! anyone know where the vacuum line on the auto tranny went, it wont shift right. Anywhere on the manifold. Link to comment Share on other sites More sharing options...
thermalsurfing1 Posted April 20, 2009 Author Share Posted April 20, 2009 thanks for the help! oh i love my lift thanks sjr for your products , next on the list..... custom roll bar ,and paint Link to comment Share on other sites More sharing options...
