rcatala Posted April 9, 2009 Share Posted April 9, 2009 Hi guys , I GOT A 1988 GL10 WAGON , I need to replace the AC compressor ,what other option I got ?,sanden 509 ,508 ? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 10, 2009 Share Posted April 10, 2009 Junkyard is you best bet. At this point the value of an '88 is going to be less than the cost of a new/reman pump. As long as you make sure it has the correct quantity of comp. oil when you charge it the pumps almost never fail. GD Link to comment Share on other sites More sharing options...
rcatala Posted April 10, 2009 Author Share Posted April 10, 2009 Thanks GD . Link to comment Share on other sites More sharing options...
idosubaru Posted April 11, 2009 Share Posted April 11, 2009 get a used compressor. someone on here probably has one for very reasonable, post in the parts wanted section. get new o-rings and schrader valves, it's only like $3 in parts and they're likely old and compromised. do that and charge it up with 2 cans of R134a and appropriate amount of oil and you're golden. Link to comment Share on other sites More sharing options...
Petersubaru Posted April 11, 2009 Share Posted April 11, 2009 Hi guys , I GOT A 1988 GL10 WAGON , I need to replace the AC compressor ,what other option I got ?,sanden 509 ,508 ? PM me if you are still interested in a compressor Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 11, 2009 Share Posted April 11, 2009 ...charge it up with 2 cans of R134a ... Let me Tell you, Respectfully: Older Subies` Air Conditioner Systems aren`t Designed to use R134a ... They use Freon R12, which is Scarse in some Countries due to environmental regulations. But I Believe that those R12 Systems can Run R134a with a Special retrofitting Kit. Kind Regards. Link to comment Share on other sites More sharing options...
idosubaru Posted April 11, 2009 Share Posted April 11, 2009 yeah there are kits all over the place here for cheap to convert from r12 to r134a. it's simple and easy. Link to comment Share on other sites More sharing options...
