The Scooby Posted April 9, 2009 Share Posted April 9, 2009 i know a few years back people talked with centerforce about a upgraded clutch disk and stronger pressure plate. with my EJ22 and 5sp d/r im running the stock EA82 clutch and has been fine since but when i replace it i would like something that grabs a little stronger. anyone have any part numbers or anything that will interchange front another car make/model for upgrades? Link to comment Share on other sites More sharing options...
michael appel Posted April 13, 2009 Share Posted April 13, 2009 sdes Link to comment Share on other sites More sharing options...
erik litchy Posted April 13, 2009 Share Posted April 13, 2009 the xt6 clutch what you have now? Link to comment Share on other sites More sharing options...
The Scooby Posted April 14, 2009 Author Share Posted April 14, 2009 no im running a stock carbed EA82, it holds fine but i would want something better when i will have to replace this one. and i don't want to run the XT6 its not that much more holding force then the EA82. Link to comment Share on other sites More sharing options...
subiemech85 Posted April 14, 2009 Share Posted April 14, 2009 http://www.ultimatesubaru.org/forum/showthread.php?t=94121 SEARCH Link to comment Share on other sites More sharing options...
Subarutex Posted April 15, 2009 Share Posted April 15, 2009 Turbo pressure plate and clutch will net you a bit extra. Best option though is to go XT6. This requires swapping the flywheel too though I believe. Link to comment Share on other sites More sharing options...
Numbchux Posted April 15, 2009 Share Posted April 15, 2009 http://specclutch.com/cars/Subaru/Leone__Loyale/1989/Single wish they had torque ratings......but no such luck. I was going to run a spec clutch on my new setup, but then decided to go EJ.... tex, only difference between EA82 and ER27 flywheels is the weight. ER27 clutch will work with an EA82 flywheel perfectly. also, some manufacturers (Beck/Arnley for sure, I've used 2 of their setups in EJ22 swaps) use the same part for turbo or XT6. Link to comment Share on other sites More sharing options...
The Scooby Posted April 15, 2009 Author Share Posted April 15, 2009 (edited) subiemech85 said: http://www.ultimatesubaru.org/forum/showthread.php?t=94121 SEARCH so how did your search help me find a AFTERMARKET clutch kit? so thanks for nothing there. ive thought of the XT6/EA82T settup but again i would like something in the 600KG range. im gonna contact Spec and see what their clutch disk material is made of ie organic or composite, and what the clamping force is on the pressure plate. Edited April 15, 2009 by The Scooby Link to comment Share on other sites More sharing options...
beataru Posted April 15, 2009 Share Posted April 15, 2009 So when you say step, you mean grind the mating surface down to the spec of the other flywheel? and then using say the xt6 clutch it would fit because the clutch is thicker? Link to comment Share on other sites More sharing options...
Numbchux Posted April 15, 2009 Share Posted April 15, 2009 beataru said: So when you say step, you mean grind the mating surface down to the spec of the other flywheel? and then using say the xt6 clutch it would fit because the clutch is thicker? yes, the step is the mating surface. yes, it is different between EA82 and XT6. but an ER27 clutch can be used with an EA82 flywheel/dimensions just fine. AFAIK, the only effective difference is the weight. Link to comment Share on other sites More sharing options...
beataru Posted April 16, 2009 Share Posted April 16, 2009 So its 6 lbs ish lighter? and how about the life of the flywheel do you machine it to er27 new specs? Link to comment Share on other sites More sharing options...
