only need 7 more HP...
suberdave
well got back on the dyno today after some more work on my car.
i was maxxing out the STI 540cc injectors. so i got a set modded by witch hunter that are flowing 780cc. now my injector duty cycle is only 65-70% where it was 113-125%
I also replaced all of my vacuume and PCV hoses. (had a hard rubber line going to the fuel reg. and it was leaking under boost, so i just replaced them all).
yes the chart is uncorrected but that is how it goes...
the boost on the dyno read ~17.5, but on both pulls my Blitz boost controller read 1.13hKpa and the ViPEC read 213Kpa. witch means i will go with the two that read the same. witch puts boost at 16.38ish...
Link to larger graph!!!
-=Suberdave=-
www.suberdave.com
Not bad at all. Got a mod list for your sti?
1988 Subaru Turbo Wagon
(Built 100% by Suberdave)
EJ20G from 96 WRX
(45K miles at time of swap, 35K since swap)
WRX 4.111:1 Trans w/ LSD R160 Rear diff
ViPEC ECU
Modded 780cc STI Side feed Injectors
05 STI Ignition Coil mod
APS Blow Off Valve
Blitz Electronic Boost control Regulator
5 lug swap (front: WRX rear: XT6)
Welwood 4pot front calipers w/ 12” rotors
XT6 rear disk brakes
Nissan 200sx rear calipers (Rear parking brake)
Tein Flex coilovers w/ EDFC (from 2005+ Legacy)
17" wheels w/ 205/40/R17 tires
255Lph Welbro Fuel Pump
XT6 Mirrors
RX body kit
Full custom 3” turbo back exhaust
eBay down-pipe and flex up-pipe
Godspeed FMIC
XT6 sway bars (24mm) front and rear
HKS turbo timer
Nardi Torino steering wheel
Momo titanium shift knob
293 at the wheels is no joke.
how do the swaybars help i tried a few setups and found mine works best with no bar in front, and a small one in back.
funny you ask, right now i have the XT6 rear and none in the front. i added some front caster and it made the XT6 front rub on the lower control arms. so i pulled it. but i like the way it handles with out it...
so we will see...
Nice car. Can't imagine how many hours you must have in it. I'm runnin' a 88 GL turbo, with some mods, but wow, can't compete with this. I've gone more off road with mine. I see that your lifted GL has a Dual Range with a locking diff. Is it possible to add this to my D/R. I have two lock/diff. trannys, 1 Turbo, 1 Reg. I've got my old 3.7 LSD all cleaned up ready to convert over to 3.9. A locking ctr. diff. would make the thing unstopable. Again, great car. S.W.
  • 2 weeks later...
