dwitsman Posted April 12, 2009 Share Posted April 12, 2009 purchased a 99 OBL that was DOA , head gasket -- pulled engine did hg job with felpro mls , heads had 2000th warpage , presssure tested and alumafluxed.Head surface polished finish ( Knowthe prob assoc with head surf being too rough) the multi step process of torquing and angle degree tighting was meticulious , POSITIVE burping was done , almost foamy mini bubbles seen in radiator still. previous owner had removed therm when purchased doa SOL. pan tested therm , yes we checked the fans 1stthing seems to regulate then bam over heats, Burped and reburped, if it is burping would it show intermittet like this ?? Drilled 1/4 hole in therm to eliminate bubble build up in h20 pump took longer to overheat than earlier but same symptoms. If it is HG issue since already did HG etc and did not fix is weakness in cooling or engine ?? Usually heads warp, does block warp in this case in the ej25d three ?? bad therm ?? probably not but did not use oem ( see above mod) burped yes HG job oem vs felpro ?? prob ?? Link to comment Share on other sites More sharing options...
mdjdc Posted April 12, 2009 Share Posted April 12, 2009 I can tell you from experience that your problem is the HG's that you used. I too have used other than Subaru HG's and they failed within 300 miles. Same engine redone with Subaru HG's and no more overheating. All HG's are not the same. Unfortunately you will have to do the job again, but I bet the engine holds once you have the new gaskets in. Good Luck Link to comment Share on other sites More sharing options...
idosubaru Posted April 12, 2009 Share Posted April 12, 2009 here i am replying to your PM. i agree with above statement. probably don't want to jump without checking some simpler things, but sounds like headgaskets. Link to comment Share on other sites More sharing options...
davebugs Posted April 12, 2009 Share Posted April 12, 2009 Well - that makes a few of us then. Link to comment Share on other sites More sharing options...
Gloyale Posted April 12, 2009 Share Posted April 12, 2009 Does it have a good Subaru OEM thermostat in it? Link to comment Share on other sites More sharing options...
idosubaru Posted April 12, 2009 Share Posted April 12, 2009 Gloyale said: Does it have a good Subaru OEM thermostat in it?no, he's got an aftermarket stat in there. Link to comment Share on other sites More sharing options...
dave833 Posted April 12, 2009 Share Posted April 12, 2009 Why oh why oh why oh WHY would anyone go to all that work and not use Subaru OEM HG's? -at least not anyone that reads this board. That's one mistake no one will make twice! Link to comment Share on other sites More sharing options...
Dr. RX Posted April 12, 2009 Share Posted April 12, 2009 Check the radiator, I did a complete rebuild on an EJ engine, only to find out it was the radiator that was causing the problem. Link to comment Share on other sites More sharing options...
davebugs Posted April 12, 2009 Share Posted April 12, 2009 I had suggested sending the rad out for cleaning and pressure testing in a PM when all this started last night. Folks run all kinds of crap through these cars in addition to a new rad cap and thermostat before realizing what the repair really entails. Perhaps the OP should post the PM's that several of us replied to. Seems like we're all basically saying the same stuff. After all we've all seen this before. Link to comment Share on other sites More sharing options...
970subaru Posted April 13, 2009 Share Posted April 13, 2009 take it to a shop with a exhaust sniffer and have them sniff the coolant res while the car is running. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 13, 2009 Share Posted April 13, 2009 burp it. Link to comment Share on other sites More sharing options...
