dbullen Posted April 14, 2009 Share Posted April 14, 2009 Does anyone know if 15" rims will fit, or will they hit the calipers? I just did an oil change, made sure I primed the oil filter, however when I refilled the oil (using full synthetic) I put in 5w30 (4.4 Litres) and approx 1 litre of 5w50 (by mistake). I'm in Canada, weather this time a year is between 35-50 degrees F. Will the 5w50 cause any issues or should I drain and refill. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted April 14, 2009 Share Posted April 14, 2009 I think you are okay on the oil. The 5w50 is less than 25% of the total amount of oil in your system, that is not much. However, since both oils are "5W", when cold, you will get good oil flow at low temperature. Nothing to worry about. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted April 14, 2009 Share Posted April 14, 2009 no problem with the oil. i doubt 15" rims will fit. but it's going to get really confusing because not all 15" rims are equal. on dual piston calipers (which you'll find your H6 has), some 15" rims fit and some do not. find some of the brake caliper threads, there's a really good one by jamal (i forget his user name). it's on nasioc as well. it lists lots of brake caliper information for upgrading but includes what wheels fit over which calipers. 15" is the limit though so some fit and some don't...i think. Quote Link to comment Share on other sites More sharing options...
dbullen Posted April 14, 2009 Author Share Posted April 14, 2009 Did some searching in the forum, but still couldn't find anything, the 15" rims I'm looking at putting on (for winter use) are the ones seen in the below pic. no problem with the oil. i doubt 15" rims will fit. but it's going to get really confusing because not all 15" rims are equal. on dual piston calipers (which you'll find your H6 has), some 15" rims fit and some do not. find some of the brake caliper threads, there's a really good one by jamal (i forget his user name). it's on nasioc as well. it lists lots of brake caliper information for upgrading but includes what wheels fit over which calipers. 15" is the limit though so some fit and some don't...i think. Quote Link to comment Share on other sites More sharing options...
MtTech Posted April 14, 2009 Share Posted April 14, 2009 After putting H6 brakes on my 98 RS, there is little room for anything between the caliper and the original 16" wheel. I doubt the 15s will work. Twin piston calipers are found on many models. In fact, I retained mine. I just used the brackets for the calipers and swapped the discs. The brackets have a greater height to account for the larger diameter disc. Quote Link to comment Share on other sites More sharing options...
