littlekicker Posted April 14, 2009 Share Posted April 14, 2009 (edited) Hey y'all, been working up my 1999 legacy outback 5MT with various mods. Right now waiting for some custom fabbed lift springs to get done and putting them on with some new kyb gr2's Does anyone know about whether it's feasible to add a dual range transfer case to this car? I think the ea81's and Ea82s had 5 speed 4x4 dual ranges in them, I also think some markets (UK and AU) had dual ranges standard in some OB's and foresters. I'm not sure what's involved, does anyone here know? Or better question, does anyone here care to chime in? I know there's adapter plates, and I know I've seen at least one car on one of those car profile sites, like car domain or something... Thanks a lot, would love to have the lo option I had with my 84 GL... Edited April 14, 2009 by littlekicker Link to comment Share on other sites More sharing options...
s'ko Posted April 14, 2009 Share Posted April 14, 2009 welcone to the Board look at the thread that i started recently about tranny options on an ej project. the post by numbchuks has a parts list. bw Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 14, 2009 Share Posted April 14, 2009 It's a matter of swapping or modifying the entire transmission - the "low range" is not a transfer case at all, but rather a split input shaft that transfers power through a low range gearset or straight through depending on the selector lever. It has nothing at all to do with the 4WD system - in fact you *can* have an EA transmission in 2WD Low (front wheel drive) if you shift in the low range gearset and not the 4WD transfer gear. I suspect that what you want is something like the european AWD dual-range transmissions but you'll find they are prohibitively expensive here. Using an EA transmission can be done with an adaptor plate but this has it's drawbacks as well - those transmissions were designed to handle 90 HP in a lighter car and most have hundreds of thousands of miles on them now. Rebuilding them, while possible, is again prohibitively expensive. You have to ask yourself - how bad do you really want low range in a vehicle that probably doesn't need it? You are looking at several thousand dollars in parts to do it right and a lot of custom labor.... for what? GD Link to comment Share on other sites More sharing options...
s'ko Posted April 15, 2009 Share Posted April 15, 2009 (edited) GeneralDisorder said: It's a matter of swapping or modifying the entire transmission - the "low range" is not a transfer case at all, but rather a split input shaft that transfers power through a low range gearset or straight through depending on the selector lever. It has nothing at all to do with the 4WD system - in fact you *can* have an EA transmission in 2WD Low (front wheel drive) if you shift in the low range gearset and not the 4WD transfer gear. I suspect that what you want is something like the european AWD dual-range transmissions but you'll find they are prohibitively expensive here. Using an EA transmission can be done with an adaptor plate but this has it's drawbacks as well - those transmissions were designed to handle 90 HP in a lighter car and most have hundreds of thousands of miles on them now. Rebuilding them, while possible, is again prohibitively expensive. You have to ask yourself - how bad do you really want low range in a vehicle that probably doesn't need it? You are looking at several thousand dollars in parts to do it right and a lot of custom labor.... for what? GD I wouldn't say several thousands of dollars. So far from the parts that I have gathered I have 300 for EA82 D/R 5 spd tranny, clutch, driveshaft, EA81 Jerry kit, and a bunch of other assorted stuff, the FT4WD tranny I am taking parts off of was from a parts car that I bought for $125 w/no engine. I estimate: machine work $50. Adapter plate is $100-180 custom driveshaft $100ish (if I go with the EA center locking diff) XT6 clutch kit $200 or custom clutch kit $300 if I want to get fancy an OBX lsd front diff for $450 so total with a EA FT4WD D/R w/the 1:50:1 low range, locking center diff, front and rear LSD. $1380.00. Can probably make it an even $1600 for unforeseen problems and some Uncle Scotty's Cocktail ingredients. This will be going into a 2k OBS w/2 inch lift and forester struts. thinking of running 27-29 inch tires. re: the EA82 tranny being able to only handle 90 hp of raw EA power, I have a EJ22T in my RX w/the EA82 FT4WD d/r. Been pretty aggressive with the car, hard launches, 1 rally cross and stuff and it shifts like a champ. Car had about 130k on the odo. I think the major limit to the holding power of the EA tranny is the clutch set up. The XT6 clutch is OK so far. We'll see how it continues to hold up. There is a 565lb curb weight difference between the 99 Outback (3200 lbs) vs the weight of a EA wagon (2635lbs), how of a factor is that remains to be seen. BTW I see that you are in Los Angeles. I have the tranny taken apart in my garage right now. When I get the upper gearset back from the machine shop, send me a PM if you want to come over and take a look. BW Edited April 15, 2009 by s'ko Link to comment Share on other sites More sharing options...
bheinen74 Posted April 15, 2009 Share Posted April 15, 2009 I would imagine this would be the same process as fitting one to the EG33 in a SVX that is getting lifted:banana: Link to comment Share on other sites More sharing options...
baccaruda Posted April 15, 2009 Share Posted April 15, 2009 To expound on s'ko's points, as an EJ 5-speed's pinion can be swapped into an EA 5-speed to change the ratios, then the guts of each transmission must be very similar (the shape of the bellhousing and the areas to which the mounts attach are different) and have similar tolerances. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 16, 2009 Share Posted April 16, 2009 (edited) Quote I wouldn't say several thousands of dollars. I was refering to rebuilding the transmission - complete syncro, bearing, and seal replacement in addition to the external parts and the labor. I was merely pointing out that it would be responsible to rebuild such a transmission if it's going into a heavier car with twice the HP. Many a used transmission can barely shift correctly on stock HP these days. Throw 170 HP at it and watch your investment drain out with the gear oil..... Uncle Scotty's is also a real bad idea. Especially after $1600 worth of parts. Anytime you mix lubricants you are just asking for trouble. GD Edited April 16, 2009 by GeneralDisorder Link to comment Share on other sites More sharing options...
