Major Lazy Posted April 15, 2009 Share Posted April 15, 2009 I put a new clutch kit in the RX (along with the jdm engine) and it squeals and when I wiggle the clutch fork side to side it stops/starts/stops. I can find a sweet spot where it stops sqealing but it does not seem to stop for long. When i put the clutch in and out it chirps. after i put the engine in I adjusted the clutch all the way out then back in until the fork was just pusing on the bearing a little. Should i even be able to wiggle the clutch fork like that? it only moves a little, like about 1/4" or less. What did i screw up THIS time? Link to comment Share on other sites More sharing options...
Numbchux Posted April 15, 2009 Share Posted April 15, 2009 sounds like it was installed correctly, some play is normal. I hope someone has another soluction....but it really just sounds like it's a bad bearing. did you put a new one in? what kind was it? Link to comment Share on other sites More sharing options...
ivantruckman Posted April 15, 2009 Share Posted April 15, 2009 i had the same thing happen to me, it was the holding spring rubbing on something. if finally went away, it must have worn down or something Link to comment Share on other sites More sharing options...
Major Lazy Posted April 15, 2009 Author Share Posted April 15, 2009 . did you put a new one in? what kind was it? A new autozone TO bearing was installed. I greased the shaft lightly and made sure the return springs were tight, it looked great (i thought) before I put the engine in. The bearing slid smoothly on the shaft and the springs pulled it back toward the tranny. What kind of damage can a bad TO bearing do if thats what it is? I sure dont want to take the engine out again this soon if I dont have to. Link to comment Share on other sites More sharing options...
