opus Posted April 16, 2009 Share Posted April 16, 2009 What do you use to add gear oil in the rear diff? I am tired of making a mess. Squirt bottle is too long. Who thought this stuff up anyways??? Grrrr! Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 16, 2009 Share Posted April 16, 2009 Most any parts stores should have a pump you can put in the bottle, like a liquid hand soap dispenser on steroids. Link to comment Share on other sites More sharing options...
opus Posted April 16, 2009 Author Share Posted April 16, 2009 Hmmm...pump goes up and down, hose falls out of hole or off of pump. Nice. Link to comment Share on other sites More sharing options...
aba4430 Posted April 16, 2009 Share Posted April 16, 2009 Lowes sells clear tubing in various sizes. All you need is a foot of the right size. Jam it on the spout end of the gear oil bottle, hold it so it does not slip off. The other end is in the differential fill hole. It is rigid enough that it will not pop out if you are careful. I use such a set up with success. Then you put the tubing in a plastic bag, label it for use again later. There will always be some mess to wipe off after you are done..... Link to comment Share on other sites More sharing options...
ivantruckman Posted April 16, 2009 Share Posted April 16, 2009 walmart sells a long transmission oil funnel for $1.99 , come on its not that bad, although the stupid air conditioning hose is in the way. Link to comment Share on other sites More sharing options...
opus Posted April 16, 2009 Author Share Posted April 16, 2009 walmart sells a long transmission oil funnel for $1.99 , come on its not that bad, although the stupid air conditioning hose is in the way. Ummm...rear diff. I havent checked though, maybe I have AC back there. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 16, 2009 Share Posted April 16, 2009 I use clear teflon tubing. 3/8" or 5/16" would work fine. Attach one end to the bottle and the other through the fill plug hole. GD Link to comment Share on other sites More sharing options...
opus Posted April 16, 2009 Author Share Posted April 16, 2009 Wow, it must be long. I have a gas tank right behind my rear diff. I cant do anything more than level for a couple feet I think. How do you keep a tube on the oily-tapered end of the bottle? You probably push the tube down to the shoulder, past the taper? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 16, 2009 Share Posted April 16, 2009 Yeah - I just shove it on. Two people make it easier I suppose but I have done it myself as well. I think I used like 36" or around that size - we stock it at work so I just cut off a chunk long enough to do the job. GD Link to comment Share on other sites More sharing options...
TomRhere Posted April 16, 2009 Share Posted April 16, 2009 I find it helps if you sit the bottle of lube in a bucket of "hot" water for a few minutes. Helps it flow easier. Link to comment Share on other sites More sharing options...
monstaru Posted April 16, 2009 Share Posted April 16, 2009 i am a fan of th epump ,as i have several things to lube usually and by gear oil by the gallon.always have it around that way too....cheers, brian Link to comment Share on other sites More sharing options...
Gloyale Posted April 16, 2009 Share Posted April 16, 2009 Hmmm...pump goes up and down, hose falls out of hole or off of pump. Nice. The pumps have a nozzle with nothched tabs that grab into the hole. It is the proper tool for the job. the easiest way. If it is too complicted for you then you are SOL Link to comment Share on other sites More sharing options...
subiemech85 Posted April 16, 2009 Share Posted April 16, 2009 remove the rear dif. works great, no mess, easy to drain ALL old oil out best done when installing LSD 21oz. Link to comment Share on other sites More sharing options...
bheinen74 Posted April 16, 2009 Share Posted April 16, 2009 was just thinking. I hate despise lube shops, have never and will never use one, but my thought is, they are supposed to change oil and top off all fluids. Wonder if they ever check the rear diff on subies? that would be considered all fluids bet not. one could probably empty the diff oil in a beater soob, take in for oil change, and then theoretically, after no diff oil got added and burned up the transmission go back on them and make them buy you a new one.....since they are contracted to check and fill as needed all fluids... evil Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 16, 2009 Share Posted April 16, 2009 years ago when I last had a shop change my oil, then also checked the rear diff fluid. They had a card with a spot for each location, and a dab of oil from each so I could see the color. Pretty slick really. If you do have a shop change it, make sure to tell them to loosen the filler FIRST, then drain it. Heard a horror story or two about that. Link to comment Share on other sites More sharing options...
