front axle replacement
85 was the first year of the "EA82"-type chassis (technically, not correct as the EA82 is an engine designation rather than a chassis identifier, but good enough for this conversation) in the sedan, coupe, and wagons. The Brat and 2-door "Hatch" continued as EA81s... totally confusing auto parts purchases until the 90 (?) model year.
Anyway, assuming that the 85 is the wider chassis with the OHC EA82 engine, and neither are turbos, the axles should interchange. Also helps the confidence level if both have the same tranny.
if they're both ea82, both the same as far as 2wd/4wd, and both non-turbo or turbo, then yes...
here's a reference I picked up off USMB a while back to help you cross reference the spline count...
--Spiffy
EA82 = EA82
doesn't matter whether it's auto/manual or 4WD/FWD
the only thing that matters is turbo/non-turbo. that would have to be the same.
if you're swapping used axles, i've found that these 80's axles hardly last a year, often breaking boots in a matter of weeks/months. the rubber boots are just old and dry rotted. hopefully you have better luck than i have.
