unibrook Posted April 21, 2009 Share Posted April 21, 2009 Just wondering if anyone KNOWS of a SPECIFIC yoke that definitely fits the Forester standard lug pattern so I can slide hammer this beeyatch hub out of the knuckle. The 5 star lug pattern measures 6.0 cm between nearest lug bolt centers. And 9.50 cm between furthest lug bolt centers. Big thanks if anyone can help. (All sorts of slide hammers with yokes available on the web, but, ahem.....hellooooo sellers, if you don't provide accurate specs in your description of the tool, how can I tell if it will fit my car?) Link to comment Share on other sites More sharing options...
porcupine73 Posted April 21, 2009 Share Posted April 21, 2009 I have no idea if this would work, but is something I was thinking about in case I ever needed to do it.... how about an old brake rotor put on backwards, maybe with a few fender washers in the middle hole with the slide hammer screw through the washers? Link to comment Share on other sites More sharing options...
unibrook Posted April 21, 2009 Author Share Posted April 21, 2009 I think that sounds perfect, but I don't have the old brake rotor. What do you think about putting the slide hammer rod thru the rotor, then attaching the washers and nut and yanking it out like that? Do you think the odds of damaging the hub are too high? Link to comment Share on other sites More sharing options...
davebugs Posted April 21, 2009 Share Posted April 21, 2009 Check w/your local Suby shop for old rotors. Of some of the cheap new rotors are under 20 bucks. Link to comment Share on other sites More sharing options...
ron917 Posted April 21, 2009 Share Posted April 21, 2009 http://www.amazon.com/OTC-7208A-Hub-Remover-Puller/dp/B0002SRF6C Use the screw to press against the axle stub or attach a slide hamer (5/8-18 thread) and bang away. Link to comment Share on other sites More sharing options...
unibrook Posted April 22, 2009 Author Share Posted April 22, 2009 This brings up a good point, my bro the mechanic warns that you might damage the axle using this forcing screw design of hub remover cuz it stresses the axle. Subaru uses the slide hammer method. Anyone ever damage their axle using the screw press method? (oh, btw, Advance Auto DOES have the adapter to fit the Subaru lug nut pattern...you just need to ask 4 different clerks about it until you find the person who knows wtf is up in his store. :-\ Powerbilt Kit #41 provides the slide hammer, Kit #40 provides the adapter yoke that fits Subaru) Link to comment Share on other sites More sharing options...
porcupine73 Posted April 22, 2009 Share Posted April 22, 2009 (edited) Not sure it would be forcing against the end of the axle shaft which is just steel or cast iron or whatever it is. It does seem that with the forcing method though it might start to push the axle stub out of the hub but the hub might still be stuck in the bearing housing? Until the axle can't compress any more then it might be putting lateral force against the joints? Edited April 22, 2009 by porcupine73 Link to comment Share on other sites More sharing options...
unibrook Posted April 22, 2009 Author Share Posted April 22, 2009 yep, it's those lateral forces against the joints that I am worried about. Link to comment Share on other sites More sharing options...
ron917 Posted April 22, 2009 Share Posted April 22, 2009 I was wondering about that myself. Haven't needed to pull a hub yet. But if the FSM says use a slide hammer, I'd just screw one on to the puller yoke. The OTC puller is designed for that, the same yoke is included in some of their slide hammer kits. I bought the puller because I have an axle job coming up. I want to have it on hand in case the axle is stuck so I don't have to hunt one down in the middle of the job. 'Course, since I have it, the axle will probably just slide out with no fuss. Link to comment Share on other sites More sharing options...
Olnick Posted April 22, 2009 Share Posted April 22, 2009 ron917 said: 'Course, since I have it, the axle will probably just slide out with no fuss. 'Course it will. But you know what would happen if you didn't have it!!! Link to comment Share on other sites More sharing options...
