P K Posted April 22, 2009 Share Posted April 22, 2009 Hello All, I have a 92 Loyale 4WD, 3AT. There is a button that I have to press to get the shifter out of park most every time. See photo. What is its true purpose? (anti-theft for the keyFOB impaired?) thanx in advance, r/ PK. Link to comment Share on other sites More sharing options...
Hondasucks Posted April 22, 2009 Share Posted April 22, 2009 That's the shift interlock. You are supposed to have to press the brake pedal in order to shift from Park, however if that mechanism malfunctions, you will have to press the button to over-ride the interlock. You should here a click sound coming from the shifter lever when pressing the brake pedal with the ignition switch on, if not, either the interlock solenoid is bad, the switch on the brake pedal is bad, or the wiring between the two is boogered up. Link to comment Share on other sites More sharing options...
subiemech85 Posted April 22, 2009 Share Posted April 22, 2009 the secret theft device makes it possible to shift into neutral without key and without stepping on brake and without battery very useful ! Link to comment Share on other sites More sharing options...
TheLoyale Posted April 22, 2009 Share Posted April 22, 2009 Heres the thing, I have a 3AT too, but when I got the car this button was missing. But it always moves out and into Park fine. So I think this button is usless. dunno why it was takin out though? btw, nothing clicks on mine. So in its place I have a switch for my front offroad lights! My $0.02 Link to comment Share on other sites More sharing options...
P K Posted April 22, 2009 Author Share Posted April 22, 2009 XLNT. Thank you all - USMB knowledge rules! Link to comment Share on other sites More sharing options...
TheLoyale Posted April 23, 2009 Share Posted April 23, 2009 XLNT.Thank you all - USMB knowledge rules! +100000!! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 23, 2009 Share Posted April 23, 2009 either the interlock solenoid is bad... BTW - these often are "stuck" due to many soda's being spilled into the center console. A good cleaning often fixes the interlock solenoind. Removing it works too and means you never need to use the button or step on the brake - which is the way I prefer it anyway. GD Link to comment Share on other sites More sharing options...
