Real quick, which wire is positive?
Brian,
I believe this was covered recently,
I think it was Miles that said it was the black one with the white stripe.
On my 82 the black one white stripe is positive and the black one with the brown rings is a ground.
Good luck,
Glenn
If they're following normal wiring conventions (as much as I learned of them livin' on the farm, at least), solid black should always be ground. It follows then that the other lead should supply the power.
'Course, if someone has rewired it, or changed things...
