hebrewhammer Posted April 25, 2009 Share Posted April 25, 2009 is the front end the same on each of these cars in 1995. Will legacy knuckles fit on an impreza wagon? Link to comment Share on other sites More sharing options...
johnceggleston Posted April 25, 2009 Share Posted April 25, 2009 hebrewhammer said: is the front end the same on each of these cars in 1995. Will legacy knuckles fit on an impreza wagon? i use these guys to check compatibility, if they say it fits , it will. http://www.car-part.com sometimes things will fit and they don't know. Link to comment Share on other sites More sharing options...
idosubaru Posted April 25, 2009 Share Posted April 25, 2009 yes....well 99% yes: the only issue you may run into is an early impreza FWD, they have different spline count on the axles. but you should be fine because i think it's only 1993 imp's that have that, only FWD, and even if it was a 93 FWD you might be okay. the axles are different but i can't recall if it's the inner joint (trans side) or outer joint (knuckles) that are different. Link to comment Share on other sites More sharing options...
MtTech Posted April 25, 2009 Share Posted April 25, 2009 '93 Imp 1.8 2WD 5 speed is the "odd one out" here. All others should go nicely together. Either way, it would be a good idea to check the splines before you install... Link to comment Share on other sites More sharing options...
