lonnie Posted April 28, 2009 Share Posted April 28, 2009 1981 brat - fuel pump wiring has gone bad. what is best alternative switched source for power? thanks. Link to comment Share on other sites More sharing options...
SUBARU3 Posted April 29, 2009 Share Posted April 29, 2009 Your voltage regulator is shot. The power to the fuel pump is supplied thru the VR. Todd Link to comment Share on other sites More sharing options...
lonnie Posted April 29, 2009 Author Share Posted April 29, 2009 thanks. i pulled the wiring diagram and traced it to the VR however i thought this must be wrong. tonight i was going to try the ignition wire in the column however i do like going back to the VR since that's where it came from in the first place. thanks. Link to comment Share on other sites More sharing options...
lonnie Posted April 30, 2009 Author Share Posted April 30, 2009 worked on wiring and found it more difficult to take power from VR for fuel pump. white wire from VR for pump is not switched but always on. ended up taking wire from radio, since i have none and used this. just hope the voltage is enough to power pump long term. Link to comment Share on other sites More sharing options...
lonnie Posted May 5, 2009 Author Share Posted May 5, 2009 my tach is now acting up - movement at times jerky, sometimes will register at certain rpms and then fall to 0, sometimes just idle and then falls to 0. is the tach mechanical and therefore the cable suspect (since that is what it is acting like). Link to comment Share on other sites More sharing options...
bratsrus1 Posted May 12, 2009 Share Posted May 12, 2009 Hi This is Jerry, look under the glove box there is a single fuse that gose to the fuel pump if it is blown no power to the fuel pump. Thanks Jerry Link to comment Share on other sites More sharing options...
RenaissanceMan Posted June 2, 2009 Share Posted June 2, 2009 Your tach is electronic. Why did you rewire your fuel pump to run off the radio?? What wiring diagram are you using? Perhaps you should just look into replacing the voltage regulator? Link to comment Share on other sites More sharing options...
lonnie Posted June 2, 2009 Author Share Posted June 2, 2009 thx for response. had trouble tracing wire for pump and the radio source was handy. this weekend expect to find fuse located by glovebox as was earlier suggested and will see if i can be correct source wire working. by the way, sourcing from radio (have removed radio and console) it has now worked for nearly a month with no problem. also, pls explain more why replacing voltage regulator might help? thanks. Link to comment Share on other sites More sharing options...
bratgrl Posted June 3, 2009 Share Posted June 3, 2009 (edited) The voltage regulator supplies the power to the fuel pump. I have been having a similar issue. The guys on here told me to try taking the "power" wire off of the fuel pump and use a jumper wire from the fuel pump to the battery and see if the fuel pump worked that way..which it did. They told me that would tell me if the V/R was bad or not. So I got a new voltage regulator, put it on, and no more fuel pump issues. Edited June 3, 2009 by bratgrl clarification purposes Link to comment Share on other sites More sharing options...
lonnie Posted June 3, 2009 Author Share Posted June 3, 2009 many thanks, i will try this. Link to comment Share on other sites More sharing options...
ferox Posted June 4, 2009 Share Posted June 4, 2009 Hey I live in Beavercreek and have a couple external VR's that you can have if you want. Link to comment Share on other sites More sharing options...
lonnie Posted June 4, 2009 Author Share Posted June 4, 2009 that would be great i will send you a PM Link to comment Share on other sites More sharing options...
