Is there any listing of acronym definitons for subarus? I did a search for some and did not find what I had hoped for. I have owned my Outback for a little over a week and while surfing the forum I get stumped on some of the terminology.
When I was on a Ford Diesel forum, we would keep a sticky thread for the newbies to read for some of the common acronyms thrown around. Example would be HPOP which meant high pressure oil pump.
Thanks.
Dean
D/R is dual range, high and low, 4wd there was a 4spd D/R and a 5spd D/R. in EA81 and EA82 cars
S/R single range, 4wd, mostly the EA71 cars
LSD.....limited slip differential, referring to rear diff. or a drug used by hippies in the 60's
doj double offset joint, as in CV axles, constant velocity axle.
etc etc.
