3Pin Posted April 29, 2009 Share Posted April 29, 2009 Will a 2000 Automatic Phase II 2.5 install clean in a 97 OB with an original Phase I 2.5 motor? Link to comment Share on other sites More sharing options...
davebugs Posted April 29, 2009 Share Posted April 29, 2009 I don't believe so. If you look at the wiring harness plugs. The 97 has 3, the newer engine has 2. I'm talking where the engine/trans meet on the passenger side. Don't know if intakes will swap - or that will be enough to make it work. You're still better off doing the 2.2 I believe. Look at how many wiring harness plugs there are. Or someone with better knowledge will confirm/deny/comment. You may get into a discussion about cam sensors/cam pulleys, ECU, etc. Link to comment Share on other sites More sharing options...
idosubaru Posted April 29, 2009 Share Posted April 29, 2009 Will a 2000 Automatic Phase II 2.5 install clean in a 97 OB with an original Phase I 2.5 motor?nope. Link to comment Share on other sites More sharing options...
3Pin Posted April 30, 2009 Author Share Posted April 30, 2009 Thanks guys. I didn't think so. Link to comment Share on other sites More sharing options...
