sub_dont_touch Posted May 2, 2009 Share Posted May 2, 2009 Hi, If someone could point out to me where the Cam and Crank Sensors are I greatly appreciate it. http://img511.imageshack.us/img511/2059/ej18.jpg thanks Link to comment Share on other sites More sharing options...
idosubaru Posted May 2, 2009 Share Posted May 2, 2009 i'm on dial up so i'm not playing with images. but they're the only sensors on the front of the engine. they are really easy to find and don't require removing anything to see, though they are surrounded by lots of stuff. both are accessible from up top, through the engine bay. and both are the closest two sensors to the front of the engine. on the right (drivers side) side of he engine is the cam sensor. it's located behind the black timing covers that cover all the timing components. it's just to the right of the oil filler tube, down on the block not the intake manifold. it'll be the only sensor bolted there with wires on it. the crank sensor is right above the timing cover in the center of the engine looking from the front. looking at the front of the engine it's the only sensor just below the alternator. sensors are easy to find - they have wires going to them. Link to comment Share on other sites More sharing options...
porcupine73 Posted May 2, 2009 Share Posted May 2, 2009 (edited) Should be roughly in these areas, at least that's where they are on all my soobs.... Edited May 2, 2009 by porcupine73 Link to comment Share on other sites More sharing options...
sub_dont_touch Posted May 3, 2009 Author Share Posted May 3, 2009 thanks for all the help. would these be correct? http://img207.imageshack.us/img207/8543/camsensor.jpg http://img164.imageshack.us/img164/8201/crankanglesensor.jpg i couldn't really see any plugs or wires on the right side. Link to comment Share on other sites More sharing options...
johnceggleston Posted May 3, 2009 Share Posted May 3, 2009 don't-touch, you may know a lot about cars and just be new to subarus and i don't mean to question your knowledge or ability, but you'll get lot's more helpful info here if you tell us what are you working on and why you want to know where they are. what are you trying to fix / correct. what problem are you having? besides, we like solving problems. if it helps any, ej18 and ej22 are almost the same engine. Link to comment Share on other sites More sharing options...
porcupine73 Posted May 3, 2009 Share Posted May 3, 2009 Hi. Hm no that first pic looks more like the engine oil pressure switch. The second pic does look like the crank position sensor. The crank position sensor is usually an orange colored sensor mounted on the top of the oil pump, kind of under the alternator, near that oil pressure switch sort of. Here it is on a 2.2L, the orange thing: cam angle sensor is also orange at least mine was on 2.2L, also orange, here it is in a few spots the orange thing. Link to comment Share on other sites More sharing options...
sub_dont_touch Posted May 3, 2009 Author Share Posted May 3, 2009 (edited) don't-touch,what are you trying to fix / correct. what problem are you having? My car won't start. So it's come to the stage where Im going to change these two sensors and hopefully thats the problem. Have tried new coil pack, checked fuses, checked cambelt, checked fuel filter. With the the CAM SENSOR I can't see in inside the or behind the right side cambelt cover (My car is right hand drive, im from New Zealand) is it possible I don't have this cam sensor? Edited May 3, 2009 by sub_dont_touch Link to comment Share on other sites More sharing options...
porcupine73 Posted May 3, 2009 Share Posted May 3, 2009 is it possible I don't have this cam sensor? If so, it might explain the starting issues. You must have a cam position sensor somewhere. I don't know that lhd vehicle engine would be any different than rhd....has to be near one of the camshafts somewhere obviousy......... Link to comment Share on other sites More sharing options...
WoodsWagon Posted May 4, 2009 Share Posted May 4, 2009 Do you have a distributor on the rear of the passenger side head? Link to comment Share on other sites More sharing options...
sub_dont_touch Posted May 4, 2009 Author Share Posted May 4, 2009 If so, it might explain the starting issues. You must have a cam position sensor somewhere. I don't know that lhd vehicle engine would be any different than rhd....has to be near one of the camshafts somewhere obviousy......... I've looked high and low and all that I personally think could be the cam sensor is the one in my photo above, it is positioned on the block below the alternator Do you have a distributor on the rear of the passenger side head? I don't know what this would look like. But I don't think so. There is a square shape coil pack timing regulator (from what i've heard). Link to comment Share on other sites More sharing options...
porcupine73 Posted May 4, 2009 Share Posted May 4, 2009 Oh good point what year is this 1.8L? Is it fuel injected? Link to comment Share on other sites More sharing options...
sub_dont_touch Posted May 4, 2009 Author Share Posted May 4, 2009 1994. yes, injected. Link to comment Share on other sites More sharing options...
