kc8apm Posted May 4, 2009 Share Posted May 4, 2009 Just wanted to get some confirmation on this -- it IS possible to do an EJ swap into a 2WD car, right? I just want to make sure that I'm not overlooking anything. Can the stock 2WD clutch handle the power? Also, I know this isn't exactly the right forum, but are the springs interchangeable among all the EA82 series cars, i.e. can I put RX springs into a DL? Kevin Link to comment Share on other sites More sharing options...
kingbobdole Posted May 6, 2009 Share Posted May 6, 2009 If I were you... I'd swap the tranny and use the EJ clutch as well... some early 2wd imprezas have 23 spline axles that will match your current axles. You just have to rig a mount and custom the linkages and you're set. Yes on the springs... Link to comment Share on other sites More sharing options...
Phizinza Posted May 6, 2009 Share Posted May 6, 2009 have a read of this thread that is still on page 1 http://www.ultimatesubaru.org/forum/showthread.php?t=97959 Link to comment Share on other sites More sharing options...
