85 BRAT exhaust with lift redo
Have an appointment at the muffler shop tomorrow to pull the exhaust back up nice and close to the body, since my 4" lift dropped it down.
What advice should I tell the muffler guy. I am not really getting a total new exhaust, mine is still good, just needs fastened back up out of the way and not hang so low.
What did you guys do to put it back up toward the body after a lift kit?
I stopped for a quick estimate today, and he asked if the middle section was a cat or a resonator. I think the CAT is up front, and it would be a resonator, should i ax that resonator if I can ? please advise by the AM.
thanks
the middle section is a resonator. just 1 single cat in the Y pipe if stock.
they'll probably just cut and add a bend after the Y pipe to take the whole thing closer to the body....
okay its all done now.
cut off the oem after the y pipe, 1/8" larger than stock tubing tucked back up into the body, re-using the stock midpipe resonator, then new 1/8" larger than stock pipe, going into the stock muffler. tucked up nicely.
cost 99 plus tax, 106.xx total
too bad this will only be useful for a few years, then the ej22t swap will need some 3" in about 4 years
now, still need to locate 32/36
