bheinen74 Posted May 4, 2009 Share Posted May 4, 2009 Have an appointment at the muffler shop tomorrow to pull the exhaust back up nice and close to the body, since my 4" lift dropped it down. What advice should I tell the muffler guy. I am not really getting a total new exhaust, mine is still good, just needs fastened back up out of the way and not hang so low. What did you guys do to put it back up toward the body after a lift kit? I stopped for a quick estimate today, and he asked if the middle section was a cat or a resonator. I think the CAT is up front, and it would be a resonator, should i ax that resonator if I can ? please advise by the AM. thanks Link to comment Share on other sites More sharing options...
mcbrat Posted May 4, 2009 Share Posted May 4, 2009 the middle section is a resonator. just 1 single cat in the Y pipe if stock. they'll probably just cut and add a bend after the Y pipe to take the whole thing closer to the body.... Link to comment Share on other sites More sharing options...
bheinen74 Posted May 4, 2009 Author Share Posted May 4, 2009 on the resonator, keep it or remove? what have other done. Link to comment Share on other sites More sharing options...
mcbrat Posted May 5, 2009 Share Posted May 5, 2009 on the resonator, keep it or remove? what have other done. it's supposed to help give it a bit more throaty sound.... I don't have one on my '82... Link to comment Share on other sites More sharing options...
bheinen74 Posted May 5, 2009 Author Share Posted May 5, 2009 okay its all done now. cut off the oem after the y pipe, 1/8" larger than stock tubing tucked back up into the body, re-using the stock midpipe resonator, then new 1/8" larger than stock pipe, going into the stock muffler. tucked up nicely. cost 99 plus tax, 106.xx total too bad this will only be useful for a few years, then the ej22t swap will need some 3" in about 4 years now, still need to locate 32/36 Link to comment Share on other sites More sharing options...
