ShawnW Posted January 13, 2011 Share Posted January 13, 2011 If you don't have the front axles solved let me know I can get you a set made here. Link to comment Share on other sites More sharing options...
Pooparu Posted January 13, 2011 Author Share Posted January 13, 2011 If you don't have the front axles solved let me know I can get you a set made here. I've got it sort of solved:-\, but I'd like a nice solid set. How much? Link to comment Share on other sites More sharing options...
ShawnW Posted January 13, 2011 Share Posted January 13, 2011 Which transmission did you end up with? Legacy if I read right but like me I bet you change your mind as you go with the build. :-) I have a 5MT D/R in mine right now so I have ea81/ea82NA spline axle shaft inboard and Impreza/Legacy/Forester outboard. The hard part is the shafts I need to find more. Link to comment Share on other sites More sharing options...
Pooparu Posted January 14, 2011 Author Share Posted January 14, 2011 Which transmission did you end up with? Legacy if I read right but like me I bet you change your mind as you go with the build. :-) I have a 5MT D/R in mine right now so I have ea81/ea82NA spline axle shaft inboard and Impreza/Legacy/Forester outboard. The hard part is the shafts I need to find more. I used a legacy transmission. What I need is legacy ends on a EA81 shaft or shortened EJ axles. All I did is had a old EJ set cut and sleeved. Once I put in the bigger motor I'm going to need something stronger. Link to comment Share on other sites More sharing options...
ShawnW Posted January 14, 2011 Share Posted January 14, 2011 As soon as I find some more shafts like mine I will get a set made and a price. Guess right now is $120/ea, exchange for any stock Subaru axle. I am working with MWE on getting these so they are sweet axles. My inner cups aren't legacy spline but that can be switched very easily. Pretty enough to put on the kitchen counter. Link to comment Share on other sites More sharing options...
aaronxs400 Posted January 14, 2011 Share Posted January 14, 2011 great build but im slightly confused so ill ask here. tell me if this sounds right. 1. XT6 control arms 2. EJ hubs 3. vw struts 4. what rotors/calipers are you using? 5. what tie rod ends? 6. legacy tranny 7. shortened EJ axles and ShawnW....what do those axles fit that you have pictured? Link to comment Share on other sites More sharing options...
Pooparu Posted January 14, 2011 Author Share Posted January 14, 2011 So these will be the right length? could you change out the ends so that they are EJ on both sides? $120.00 each is a great price. I'll take 'em with an exchange. I'll let you know when I have the money together. Then I'll ship you a set of axles. As soon as I find some more shafts like mine I will get a set made and a price. Guess right now is $120/ea, exchange for any stock Subaru axle. I am working with MWE on getting these so they are sweet axles. My inner cups aren't legacy spline but that can be switched very easily.Pretty enough to put on the kitchen counter. Link to comment Share on other sites More sharing options...
Pooparu Posted January 14, 2011 Author Share Posted January 14, 2011 1. EA81 Control Arms (modified to fit the EJ ball Joints) 2. EJ Hubs 3. VW Struts 4. WRX rotors/calipers 5. EA81 Tie Rod Ends 6. 4.111 Legacy AWD Transmission 7. Shortened EJ Axles 8. EJ ball Joints I've probably got at least 6-7 different styles of subarus & a VW & Toyota parts built into this 1982 Hatch. It's amazing I can still remember the combination of them all. great build but im slightly confused so ill ask here. tell me if this sounds right. 1. XT6 control arms 2. EJ hubs 3. vw struts 4. what rotors/calipers are you using? 5. what tie rod ends? 6. legacy tranny 7. shortened EJ axles and ShawnW....what do those axles fit that you have pictured? Link to comment Share on other sites More sharing options...
aaronxs400 Posted January 14, 2011 Share Posted January 14, 2011 (edited) what did you have to do to get the ej ball joints to fit? what year wrx? O and what knuckles? Edited January 14, 2011 by aaronxs400 Link to comment Share on other sites More sharing options...
Pooparu Posted January 14, 2011 Author Share Posted January 14, 2011 - I used a die grinder on the opening on the EA81 control arms. - 2002 WRX - Legacy knuckles what did you have to do to get the ej ball joints to fit? what year wrx? O and what knuckles? Link to comment Share on other sites More sharing options...
ShawnW Posted January 15, 2011 Share Posted January 15, 2011 So these will be the right length? could you change out the ends so that they are EJ on both sides? $120.00 each is a great price. I'll take 'em with an exchange. I'll let you know when I have the money together. Then I'll ship you a set of axles. They fit in my 83 Wagon with 5 lug conversion. I need to test drive the car and haven't got it back together but they fit sweet and I don't see why they wouldn't be just fine. Ill get some testing done before we complete transaction and get the price firmed up. Link to comment Share on other sites More sharing options...
Pooparu Posted January 16, 2011 Author Share Posted January 16, 2011 They fit in my 83 Wagon with 5 lug conversion. I need to test drive the car and haven't got it back together but they fit sweet and I don't see why they wouldn't be just fine. Ill get some testing done before we complete transaction and get the price firmed up. Sounds great:) Link to comment Share on other sites More sharing options...
Pooparu Posted April 13, 2011 Author Share Posted April 13, 2011 Hey Shawn any word on the axles yet? Link to comment Share on other sites More sharing options...
LeoneTurbo Posted April 14, 2011 Share Posted April 14, 2011 I would be interested in a set of axle shafts aswell if I can fit EJ joints wheel side. Link to comment Share on other sites More sharing options...
renob123 Posted April 18, 2011 Share Posted April 18, 2011 Shawnw's price is pretty good, so I'm not sure if it would be worth trying, but couldn't you just use hatch/Brat/Leone shafts and put the EJ inners/outers on? Jacob Link to comment Share on other sites More sharing options...
LeoneTurbo Posted April 19, 2011 Share Posted April 19, 2011 Nope, splines on the shaft are different between EA81 and EJ-series. Link to comment Share on other sites More sharing options...
renob123 Posted April 19, 2011 Share Posted April 19, 2011 Nope, splines on the shaft are different between EA81 and EJ-series. Oh, ok. They were the same on the aftermarket axles I got. I've heard that they're the same between a lot of generations of Subarus, but I guess not this combination. Jacob Link to comment Share on other sites More sharing options...
Gloyale Posted April 19, 2011 Share Posted April 19, 2011 Nope, splines on the shaft are different between EA81 and EJ-series. There are 2 different diameter of EA81 shafts. One of them is the same as the 90-98 EJ axle cups. I use Legacy rear DOJ's (23 spline) to repair EA81 axles all the time. Link to comment Share on other sites More sharing options...
Pooparu Posted April 21, 2011 Author Share Posted April 21, 2011 I think the fronts are a different story. I tried every combination I could get my hands on to make them work. All I need is for both EJ ends to fit on my EA81 shaft. That's not to say that there may be a combination that works. There are 2 different diameter of EA81 shafts. One of them is the same as the 90-98 EJ axle cups. I use Legacy rear DOJ's (23 spline) to repair EA81 axles all the time. Link to comment Share on other sites More sharing options...
Pooparu Posted April 21, 2011 Author Share Posted April 21, 2011 Shawnw's price is pretty good, so I'm not sure if it would be worth trying, but couldn't you just use hatch/Brat/Leone shafts and put the EJ inners/outers on? Jacob Tried it and it's didn't work. Link to comment Share on other sites More sharing options...
renob123 Posted April 21, 2011 Share Posted April 21, 2011 Tried it and it's didn't work. Hmm, yeah, I sort of assumed you tried, or else you wouldn't have done the welding/sleeving thing. I know you can do it with EMPI axles, but you'd be hard-pressed to beat ShawnW's price. Jacob Link to comment Share on other sites More sharing options...
Pooparu Posted April 21, 2011 Author Share Posted April 21, 2011 Hmm, yeah, I sort of assumed you tried, or else you wouldn't have done the welding/sleeving thing. I know you can do it with EMPI axles, but you'd be hard-pressed to beat ShawnW's price. Jacob Well I might have to go that route if I don't hear back from him. Link to comment Share on other sites More sharing options...
whitesti400 Posted July 7, 2011 Share Posted July 7, 2011 This has some great info!!! I may have some questions for you in the future. Link to comment Share on other sites More sharing options...
