Krustles Posted May 5, 2009 Share Posted May 5, 2009 I am having the hardest time trying to get my crank pulley off my 93 impreza. Does anyone have any tips? i got the bolt off but the pulley will not budge. Thanks in advance Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 5, 2009 Share Posted May 5, 2009 oh yeah, that's really annoying. wear some gloves and grab each side and keep wiggling it. it'll seem like you're not doing anything, but keep trying. rotate 90 degrees and try again. a leveraging instrument placed behind it with some careful but stiff forceful nudges from behind helps too, but i would call that a last resort. good luck, they're really annoying sometimes. Quote Link to comment Share on other sites More sharing options...
davebugs Posted May 5, 2009 Share Posted May 5, 2009 Rubber mallet is something that I try - of course I usually have the engine out. Then I progress from there. But after is start to move it just takes patience. As GG eluded to there is no real good place to pry against. SOmetimes I'll actually re-install the alternator bracket to try and use it. Quote Link to comment Share on other sites More sharing options...
avk Posted May 5, 2009 Share Posted May 5, 2009 (edited) I ended up using a three-jaw puller. It was actually assembled from three different ones: forcing screw from the first (others too long to fit), jaws from the second (others would slip), link bars from the third (to make it all work together). But cutting threads in the holes and using a steering wheel puller seems like the correct way to go if you got a stubborn one. With a puller, you also need to insert some sort of spacer that would bottom out in the crankshaft hole so as not to damage the threads. Edited May 5, 2009 by avk Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted May 6, 2009 Share Posted May 6, 2009 It's probably a little (or a lot) of rust keeping it on the shaft. In addition to the above, try to get some good penetrating oil in there. Quote Link to comment Share on other sites More sharing options...
edrach Posted May 6, 2009 Share Posted May 6, 2009 a leveraging instrument placed behind it with some careful but stiff forceful nudges from behind helps too, but i would call that a last resort. good luck, they're really annoying sometimes. Careful leveraging. The timing cover breaks easily. Quote Link to comment Share on other sites More sharing options...
