lv426 Posted May 5, 2009 Share Posted May 5, 2009 this motor use to run great and I have nothing at the fuel injectors. I see information saying no reference pulse but they don't say what to check to solve the problem? I have spark, but no fuel injector click. I don't know. Is it time to take it to the dealership. This is an ea82t. Many people have suggested this site for help so here I am. Thanks Link to comment Share on other sites More sharing options...
Cougar Posted May 5, 2009 Share Posted May 5, 2009 Welcome to the forum. The trouble you are having may be due to a bad crank angle sensor. It is under the plate in the distributor. Make sure it has power getting to it. Link to comment Share on other sites More sharing options...
naru Posted May 6, 2009 Share Posted May 6, 2009 this motor use to run great and I have nothing at the fuel injectors. I see information saying no reference pulse but they don't say what to check to solve the problem? I have spark, but no fuel injector click. I don't know. Is it time to take it to the dealership. This is an ea82t. Many people have suggested this site for help so here I am. Thanks What year?? It matters. Forget the dealer.Collective EA-82T knowledge base is larger on this forum.We will get you running. CAS(if equipped) is OK if you have spark. Any codes other than the missing ignition reference pulse? If you have no volts on the injectors,check the fusible links. Link to comment Share on other sites More sharing options...
