tbcboo Posted May 11, 2009 Share Posted May 11, 2009 So I've used Seafoam on my subaru WRX before and also other cars with good results. I'm not very mechanically inclined and this is my first carb'd car. Can anybody explain the best places to add seafoam to a '84 Subaru GL? If you have a link with pics that would be great, because most likely I won't know where part/hose X is. Thanks Link to comment Share on other sites More sharing options...
edrach Posted May 11, 2009 Share Posted May 11, 2009 I put some in the oil to get rid of the sludge in an old motor. I put the rest in the gas tank . I don't think you need pics for that. Link to comment Share on other sites More sharing options...
markjw Posted May 11, 2009 Share Posted May 11, 2009 You can also get your engine good and warm,and while its idling,slowly pour it into the throat of your carb. Your engine will want to stall,but just slow down spilling it into the carb and let the engine recover. Do this till about half the can is in the carb/engine then give it a Big drink to kill the engine. Turn off your ignition and let your car sit for about ten minutes. While your waiting,pour the remaining Seafom into your gas tank. Start it back up and go for a drive. Drive around till the exhaust clears up. Thats what I do. And it should give you a better/smoother idle. Link to comment Share on other sites More sharing options...
tbcboo Posted May 12, 2009 Author Share Posted May 12, 2009 ^^^^Thats what I was looking for. Thanks! I obviously know about pouring it into the gas/oil but mainly looking for vacuum line etc. Link to comment Share on other sites More sharing options...
