EA82 engine and transmission mounts...
My 86 Leone needs new mounts... I want to replace all of them. However, after doing some searching at the auto parts store they are an abysmal ~$400 for all of them! There's no way I'm spending that kind of money on engine mounts.
Does anyone make custom ones on here that are solid steel or anything? I don't care if the car vibrates, I'm just sick of the engine and transmission thunking around.
Wow, I can't believe how expensive those are. The last mount I bought was for my F250 and it was only about $25 for a huge thing.
You don't want solid mounts, as the flexing of the body will crack the bellhousing. What mount is bad, or are they all?
Hey,
Not sure where you live...or even if this is exactly what you're looking for.
Doug
1986 SUBARU GL 1.8L 1781cc H4 FI (5) : Engine : Motor MountPriceCoreTotalAdvice.gifANCHOR Part # 8641 MoreInfo.gif {AUTOMATIC TRANS}
ANCHOR Part # 8640 MoreInfo.gif {MANUAL TRANS}
Rear w/ MT* Non-stock item--shipping delayed up to 2 business days8640.jpg
RockAuto
It has been said many times here: BE CAREFUL WITH ROCKAUTO! their catalog is inacurate.
It is better to spend more but get the right stuff!!!
Sam
Hey,
Make sure you click on the right VIN. Make sure you have the right DL, GL and so forth. Any questions, call. Works for me.
Doug
Edit: thepartsbindotcom has them. Good selection. Current listing on eBay for tranny mounts as well. FYI.
Edited by Quidam
add text
