I got my gaskets!
Came with all the gaskets and plus some...
I dont know how to put the valve stem gaskets on so I guess ill skip those?
I just want to know everything To do before and after putting the gaskets on and to use a good sealent to make the gasket between the cam case and the head. I also need new head bolts?
Valve stem seals are about the easiest part of the job. If you don't have a valve spring compressor, rent one. Get the big c-clamp style one since you'll have the heads off. Compress the spring, pull out the retainers, SLOWLY release the spring, pull off the old seal, slide on the new one, and put the spring and retainers back on. The procedure is given in a bit more detail in your manual.
What about the EA71 head studs?
All Subaru bolts/studs are reusable. Even the torque to yeild variety are rarely replaced in practice. In fact most of the techs just torque them to a ft/lbs value rather than following the manual procedure for the EJ's. For anything prior to the EJ's the studs/bolts are not called out for replacement unless they are damaged.
