84gl Posted January 21, 2004 Share Posted January 21, 2004 any help with the wiring will be appecited all i need is to get fire i'll manage the rest but like said i run a hot wire to the + side of the coil and still no fire i have a good coil and a transter distributor yellow wire to the + side and the black one to the - side Link to comment Share on other sites More sharing options...
torxxx Posted January 21, 2004 Share Posted January 21, 2004 I'm not mudrat, but this may help check your fuseable links. They are in that black box right in front of the coil You may have burned one of those out and that would amke you not get spark Link to comment Share on other sites More sharing options...
84gl Posted January 21, 2004 Author Share Posted January 21, 2004 thanx but that would not matter the way i have it wired up with a kill switch Link to comment Share on other sites More sharing options...
84gl Posted January 22, 2004 Author Share Posted January 22, 2004 any help with the wiring will be appecited all i need is to get fire i'll manage the rest but like said i run a hot wire to the + side of the coil and still no fire i have a good coil and a transter distributor yellow wire to the + side and the black one to the - side __________________ Link to comment Share on other sites More sharing options...
75skunkaroo Posted January 23, 2004 Share Posted January 23, 2004 have you tried the yellow wire to the negative side of the coil and the black/yellow one to the positive? this worked on mine Link to comment Share on other sites More sharing options...
ThreeEyedBandit Posted January 23, 2004 Share Posted January 23, 2004 On my car the Balck/Yellow wire from the dist goes to the Pos. and the Yellow wire from the Dist. goes to the Neg. But it is and 82'. I will go check an 84' wagon and have an answer by the end of the night. Matt Link to comment Share on other sites More sharing options...
