kdixey Posted May 16, 2009 Share Posted May 16, 2009 Okay this will seem like nothing to most of you but my clutch cable broke and I was able to fix it by using this board by searching for "broken clutch cable" and seeing what others had done. BTW, it was NOT the easiest thing I've ever done on my car. Its a PITA to get the cable hooked to the clutch pedal and I am still having trouble getting that second bolt into the little block that the cable comes out of. ...but the car works, so HOZZZZAH!!! Kevin Link to comment Share on other sites More sharing options...
